04-07-2019 03:12
04-07-2019 03:12
My fitbit screen starts "glowing" 2 - 3 times prior to when I wake up. It does so at other times as well.
Any way of stopping that irritating behavior?
Thanks.
04-07-2019 05:16
04-07-2019 05:16
Hi, try this: restart your Versa 4-6 times in a row by pressing and holding the left and right lower buttons together untill see the Fitbit logo and release the buttons. This procedure solves most of these problems.
04-07-2019 05:22
04-07-2019 05:22
It may have worked, but it wiped out my 1000 step walk I had after breakfast.
04-07-2019 05:37
04-07-2019 05:37
That's weird, it's the first time I hear that after this procedure data are lost. Do not have an explanation for it, cause the only thing you've done is restart the watch and not a Factory Reset 🤔,
04-09-2019 01:28
04-09-2019 01:28
It did not help.
That would be a good item for a Fitbit to do list.
04-09-2019 01:50
04-09-2019 01:50
I'd restart 8-12 times, just to be double sure that it has restarted. You never know.
04-09-2019 03:25
04-09-2019 03:25
I don't know. My fingers are getting sore doing that. 🙂
05-05-2019 13:29
05-05-2019 13:29
Here is my fix for that annoying Fitbit bug. I just use it at night.
The light is so bright, I had to sew on another layer. 🙂
10-07-2020 15:54
10-07-2020 15:54
Mine is the same I only bought it yesterday and all night it kept glowing in the dark it’s so annoying. I thought it maybe a fault but gland I’m not alone
