08-20-2024 05:18
08-20-2024 05:18
My Versa 2 is apparently dying. First very bright green screen. And when I wanted to charge it, it get overheated. I almost burned myself. And even after an hour it is still this hot. Anyone else has had this issue?
08-20-2024 05:39
08-20-2024 05:39
@krismaldo It sounds like your Versa 2 developed a battery fault. Please don't try charging it any more. It is broken and you should dispose of it according to your local e-waste recycling rules.
This can happen with any rechargeable battery and isn't unique to Fitbit batteries.
Laurie | Maryland
08-20-2024 05:45
08-20-2024 05:45
Yes, you're probably right about this. So sad cause the versa 2 is only just 2 years old. Thank you for your reply.
