01-01-2019 12:51
01-01-2019 12:51
Since a week or so my heartrate seems to be significally higher. Even if I just sit I get a bpm of 90 or so in the fat burning zone. Or is goes fron 60 to 90 in seconds. My condition is fine and I dont feel any different so rather than calling the hospital I am going to assume my Heartrate monitor is a bit confused. I also noticed that my hr was even 100 when not wearing it. It used to be accurate and constant before. I have done a reset and cleaned it. Not convinced it worked so far. Anyone else had this or has any suggestions?
Best Answer01-01-2019 19:25
01-01-2019 19:25
@Gwaihira Please go to Settings app on your Versa (swiping left), tap it and scroll down to heart rate. Please toggle it ON and OFF with a reboot of versa in between. You can reboot your tracker by pressing and holding the left and bottom right buttons until Fitbit logo flashes.
01-01-2019 19:25
01-01-2019 19:25
01-09-2019 07:14
01-09-2019 07:14
Thank you. It worked. Funtioning normal again
Best Answer01-09-2019 14:43
01-09-2019 14:43
@Gwaihira I'm glad I could help! 😊
