12-16-2019 11:59
12-16-2019 11:59
I did factory reset on versa after which the screen is blank
I have charged for more than an hour but still it's dead
Tried pressing all 3 buttons at the same time but still no signs of working
What should I do now?
FYI- before I did a factory reset, I had my versa charged to 100% (battery full). As soon as I gave factory reset while it was on charge, the screen went blank with no signs.
Please help to sort our asap
12-16-2019 12:12
12-16-2019 12:12
Why did you do a factory reset? Have you held in the left button long enough to turn on? Does the tracker work while plugged in?
A factory reset is done by holding in the left and lower right.
Do you get any vibrations.
Best Answer12-16-2019 17:16
12-16-2019 17:16
