01-02-2019 12:18
01-02-2019 12:18
Hi, my new Fitbit Versa on works when on charger. My batterie says 100% on the charger. When I take the watch off the charger the screen is black and wont open!
Please help
01-02-2019 20:10
01-02-2019 20:10
I am having this exact same problem. Day 1 of my new Versa with absolutely no luck in using it. Very frustrating.
01-03-2019 00:04
01-03-2019 00:04
I'm going to start with the obvious, forgive me if you have already done it, it's a process.
Have you setup the watch on the app according to the installation instructions? Setup
If you have set it up make sure it is not currently downloading or trying to install the latest firmware/software you will be unable to use the watch until this is complete.
Have you tried restarting the watch, hold the left and bottom right buttons until the logo appears and the watch vibrates.
01-03-2019 06:53
01-03-2019 06:53
01-10-2019 15:51
01-10-2019 15:51
Same issue here. Have had my versa since september and working great. Yesterday it went blank at 60% battery. As soon as I placed on charger it powered up and turned on. At 100% took it off and went blank again.
Today I restored to factory settings and started all over. Thought I was in luck but first time I took it off the charger it shut off again. Any solutions??
01-14-2019 20:23
01-14-2019 20:23
01-15-2019 21:50
01-15-2019 21:50
It seems to be a lucky dip. Some get one that works well while many others get one that fails almost immediately. With today's technology there should not be anywhere near as many failures as there seems to be, especially where the battery is concerned. Perhaps if they had bothered to implement a replaceable battery then perhaps there would be fewer entire units being sent back as faulty.
I had 2 Ionics fail within 4 months of each other but have so far been lucky with the versa, though it is still less than 6 moths old yet.
It would make for interesting reading to see the books showing the number of faulty items returned, but that'll never happen at least not publicly. Many of the issues appear to be battery related (but that is only going from the comments posted here, I could be way off in my view)
02-19-2019 12:34
02-19-2019 12:34
I am having this exact problem since last night. Today I decided to do a factory reset while on charger and tried a fresh setup. But now my phone app won't connect to the watch. It seems there is an issue with the watch Bluetooth.
Any ideas?
02-19-2019 21:35
02-19-2019 21:35
@Beth6181 wrote:I am having this exact problem since last night. Today I decided to do a factory reset while on charger and tried a fresh setup. But now my phone app won't connect to the watch. It seems there is an issue with the watch Bluetooth.
Any ideas?
Mine did the same thing to me yesterday, I rebooted the watch and also rebooted the phone, then I turned off the Bluetooth and started it again and all is working again. Although my Versa did reboot itself today when I tried to activate an exercise activity so I had to manually reboot it again, so far it is still functioning normally.
You could also try removing the versa from your account and then add it back in as a new device (could be risky if there is an issue with the battery or Bluetooth though)
02-22-2019 07:13
02-22-2019 07:13
I would like to return this watch. It goes dead when removing from charger and still not synching. Bought it last November and been using it since end December.
Can I get some help from Fitbit? Thanks
07-24-2019 05:48
07-24-2019 05:48
@Gennie1 Same thing is happening to me!
08-30-2019 11:23
08-30-2019 11:23
I have had this Versa since April, and it has worked well until now. Starting this afternoon, the screen went blank even though the battery was at about 70%. I put it on the charger, and it lights up again. As soon as I take it off, it goes blank. It is now at 100% battery but will not work unless it is on the charger. Any thoughts or help to offer?
08-30-2019 14:49
08-30-2019 14:49
@SunsetRunner I finally had to get Fitbit to replace the Versa, they did it about a month ago. Very satisfied with the customer service I received.
07-17-2020 12:01
07-17-2020 12:01
Me too. It started 07/17/2020
07-17-2020 12:24
07-17-2020 12:24
I ended up ditching my Versa in favor of an Apple Watch, and I’m very happy with the swap. I’ve had zero issues with the AW after having three Versas fail in about 9 months.
