11-23-2018 00:29
11-23-2018 00:29
Please help me.
I have fitbit versa on software version 32.32.12.19 and my mobile is galaxy s9 plus software is 8.0 oreo iusse is that i cant receive phone call notification in on versa And the notification that is within the Fitbit application, the phone call I pressed it, even if my mobile phone does not show the demo on my mobile phone call.its mean fitbit aap bugs please help me
11-23-2018 21:46
11-23-2018 21:46
@Kayani Is it only phone call notifications that you're not receiving? Are you getting other notifications? Try turning off and on Bluetooth on your phone as well as rebooting your Versa several times by pressing and holding the left and bottom right buttons at the same time until Fitbit logo flashes.
11-23-2018 22:16
11-23-2018 22:16
11-23-2018 23:47
11-23-2018 23:47
@Kayani I understand you're not getting call notifications on your Versa. Are you getting text messaging or other types of notifications on your versa? Does your versa sync properly? Finally, can you please share your Android version?
11-24-2018 01:05
11-24-2018 01:05
11-24-2018 09:31
11-24-2018 09:31
I am having the same issue. Same type of phone also. No call alerts and no text notifications
11-24-2018 10:14
11-24-2018 10:14
I am also having the same problem
@Kayani wrote:Please help me.
11-24-2018 11:14
11-24-2018 11:14
Hello @Kayani, @Manaskhera and @Chicago97, have a warm welcome to the Fitbit Community, it's great to have you on board. It's great to see you too @Marrrmaduke, I appreciate all your help.
@Kayani, @Manaskhera and @Chicago97, I appreciate your participation in the Forums and for sharing your experience with us. If you have already checked the troubleshooting steps provided by @Marrrmaduke and you're still having trouble receiving Notifications, please try the following:
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
11-24-2018 17:54
11-24-2018 17:54
@Chicago97 Thank you for letting me know that you're not getting any notifications. My next question would be - does Versa sync at all? Please try this:
Note: Please make sure the Notifications are on your Versa - press and hold the left button to access Quick Menu. Notifications should be ON.
11-28-2018 08:19
11-28-2018 08:19
Still does not work. I was on the phone with a person for and hour. Your firmwear is flawed for note8 and s9 . What a joke. I did everything 4 times and then we decided to try it on the s5 AMD it works perfect... but problem is I have a note8!!!
11-28-2018 13:43
11-29-2018 07:56
11-29-2018 07:56
I have tried everything possible. I hope they work out these little kinks. I will say if half works. ( If I get a call and I don't answer it from my phone it will vibrate one time on the versa. But onlly if the called was missed. )Very strange. And I get a notification when i get a text but cannot see the text or cannot respond.
11-29-2018 13:10
11-29-2018 13:10
@Lburgett Could you please quickly remind me what your Versa firmware version is and the Fitbit mobile app version?
11-29-2018 21:27
11-29-2018 21:27
11-30-2018 13:54
11-30-2018 13:54
32.32.12.19 on versa and same on my note 8
11-30-2018 20:04
11-30-2018 20:04
@Lburgett Thanks, please make sure you can read the body of the message in the Notification Center Bar of your phone. If you cannot, it means that the message content is hidden/private. You need to allow preview of your messages in the message app settings on your phone. The preview needs to be visible in the Notification Centre. Also, I recommend switching to native/default messaging app.
11-30-2018 20:06
11-30-2018 20:06
@Kayani There is not such thing as Always-on display as it would drain your battery rapidly. Now having said that, there are several clockfaces you can install that will allow that. Unfortunately, I do not remember their names. You cannot browse this forum for more info.
12-26-2018 17:57
12-26-2018 17:57
I'm getting text messages, and missed call one vibration once call is missed. It just won't tell me when an actual call is coming in, only when it has been missed. It's been updated. 32.33.1.30. I have checked every setting in my phone have reinstalled factory reset my versa, uninstalled application etc.
12-27-2018 17:33
12-27-2018 17:33
@Lburgett please go to settings on your phone, scroll down to Apps, tap and open Application List. Tap on the three dots in the right top corner, and select Show System Apps. Scroll down through the app list to something like Call Management. This might be called differently on your device. Open it and tap on Notifications. Make sure that Incoming calls are set to Urgent or High.
Reboot your phone and Versa, and sync.
12-27-2018 20:26
12-27-2018 20:26
Had the same issue with S7. Go to settings on the phone, select date and time. If 'auto time' is turned off simply turn it on. This has worked for me and others. I think the auto time must have been turned off during an update cuz I noticed my phone time was behind by 2 minutes.
