11-23-2018 00:29
11-23-2018 00:29
Please help me.
I have fitbit versa on software version 32.32.12.19 and my mobile is galaxy s9 plus software is 8.0 oreo iusse is that i cant receive phone call notification in on versa And the notification that is within the Fitbit application, the phone call I pressed it, even if my mobile phone does not show the demo on my mobile phone call.its mean fitbit aap bugs please help me
12-27-2018 20:29
12-27-2018 20:29
@Versa-tility and auto-time being switched off caused the lack of phone calls notifications?
12-28-2018 05:10
12-28-2018 05:10
12-28-2018 12:41
12-28-2018 12:41
@Versa-tility thank you for sharing this tip! This will help other users!😊
12-30-2018 14:58
12-30-2018 14:58
I went in an reset my settings on my note 8 and it worked!
For anyone else that needs help with this issue.
1st. Make sure versa has been updated to the new firmware.
2nd. Disconnect from bluetooth, delete versa
3rd. Go into your phone settings >general managment > reset all settings to their default.
4th. Go to settings>general management >reset.
5th. Go to settings>notifications>make sure fitbit app and messaging app and email app (email only if you want notifications) set to ALLOW these apps.
Restart versa.
Restart phone.
Connect bluetooth on phone to pair with versa
Go into fitbit app
Click on the versa watch at the top right corner.
Now
Turn on all day sync.
Scroll down....
Turn on Always connected and
Turn on Keep widget alive
Scroll up...
Click on notifications >turn on calls
Go into app notifications make sure, FITbit contacts, messaging apps and emails are all on.
While still in this settings notifications area in the fitbit app,
Go to the top right corner with three dots, click that and click send a test call notification.
Hopefully it works!
If it doesn't, go to the sync in the fitbit app and sync and then try again.
If it does not, you should delete the device and set it up again like a new versa and adjust settings as said above in fitbit app. And the notifications in the phone. Good luck.
12-30-2018 15:10
12-30-2018 15:10
01-01-2019 07:27
01-01-2019 07:27
Hello everyone, I hope you're doing well.
I appreciate some of you have come back and let us know your issue has now been resolved and are now receiving Notifications. I would like to thank you for listing the steps you've followed in order to resolve this issue.
Now, if you're still having trouble receiving Notifications on your Versa from your Samsung Galaxy 9+, please let us know so we can check this further.
Thanks for your patience and understanding, we'll be waiting to hear from you.
01-01-2019 22:46
01-01-2019 22:46
This could have possibly been my problem. Resetting phone to default settings made it go back to Auto time. Who knows. But I'm sure glad my Versa is functioning properly. 🙂 My friend has a Note 8 and it worked.seamlessly for her, so I knew something was up with my phone settings.
01-02-2019 04:02
01-02-2019 04:02
02-09-2019 00:26
02-09-2019 00:26
hello everybody. THIS MESSAGE to FITBIT TEAM
i had pebble steel first - no problem
later i had pebble time steel - was some issues with connection to phone, but pebble solve them
now i have versa!! i want to buy a gadget and to use it from box! why i need to "dance"?
first: notification service not running. solve by adding it to autorun. NO such promlems with pebble or mibands. THE SAME TECHNOLOGY!! SAME ANDROID!
second: calls notification. solve by auto-time switch. NO such promlems with pebble or mibands. THE SAME TECHNOLOGY!! SAME ANDROID!
maybe you have a QA manager vacancy - i can solve all your problems! 🙂
