12-26-2018 19:38
12-26-2018 19:38
How do I lock my fitbit versa with a pin without it also locking my phone? I dont want my phone to have a pin as it's just annoying, but want my Fitbit to have it on.. help!
12-26-2018 19:58
12-26-2018 19:58
@Jemmadilemma92 The only time the pin code would be required on your phone is if you incorrectly enter a code 10 times. Then it asks you to unlock it with your phone. Are you experiencing something different? More info in a help article here.
12-26-2018 20:10
12-26-2018 20:10
Hi Jrdubyakc
That's not what is happening.
I went into the settings on the fitbit app and put the screen lock on my fitbit (so I would have to type in a pin to unlock my fitbit) but it also put the same pin lock on my phone (So I had to type the pin into my phone every time I wanted to use my phone). The pin never actually went on my fitbit, it still swiped to unlock.
I'm wanting to know how to put the pin lock on my fitbit without it putting the same lock onto my phone.
12-26-2018 20:13
12-26-2018 20:13
Hi @Jrdubyakc
That's not what is happening. I went into the settings on the fitbit app and put the screen lock on my fitbit (so I would have to type in a pin to unlock my fitbit) but it also put the same pin lock on my phone (So I had to type the pin into my phone every time I wanted to use my phone). The pin never actually went on my fitbit, it still swiped to unlock. I'm wanting to know how to put the pin lock on my fitbit without it putting the same lock onto my phone.
