11-24-2018 18:52
11-24-2018 18:52
I bought the fitbit versa in may after being a previous fitbit lover.... started with Alta, upgraded to charge 2 then moved onto versa after charge 2 (which i loved) screen suddenly stopped working. Well unfortunately after paying over 200 pound for my versa rose gold edition only 7 months ago has stopped working in my sleep. The screen will not work..... 1 pixel will light up but i was asleep and take good care of my fitbit as it was my pride anr joy walking daily over 10 miles just to work and back each day. Taking part in challenges workweek hussle ect..... now left disappointed. In total ive spent over 500 pound on fitbits in 3 years. What can i do about this fitbit
11-24-2018 20:36
11-24-2018 20:36
@Charlie89 wrote:I bought the fitbit versa in may after being a previous fitbit lover.... started with Alta, upgraded to charge 2 then moved onto versa after charge 2 (which i loved) screen suddenly stopped working. Well unfortunately after paying over 200 pound for my versa rose gold edition only 7 months ago has stopped working in my sleep. The screen will not work..... 1 pixel will light up but i was asleep and take good care of my fitbit as it was my pride anr joy walking daily over 10 miles just to work and back each day. Taking part in challenges workweek hussle ect..... now left disappointed. In total ive spent over 500 pound on fitbits in 3 years. What can i do about this fitbit
I recommend that you contact support. Contact options can be found at the following link: https://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs Good Luck!
11-24-2018 20:43
11-24-2018 20:43
@Charlie89 Try rebooting your Versa several times by pressing and holding the left and bottom right buttons until Fitbit logo flashes. If this does not help, attempt 3-button factory reset. This will wipe all the data from your Versa, and you will need to set it up again:
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
If you're not successful, you will need to contact Customer Support as it might be a hardware issue. The good thing is your Versa should still be under warranty.
