09-02-2019 13:36
09-02-2019 13:36
My tracker wouldn’t sync. I tried restarting the app, my phone, my tracker. Tried turning them all off and on. Tried turning Bluetooth on and off. Tried - forget this device and re-setting up and nothing is working. I’ve tried everything but not the set up won’t even recognise my tracker! Not sure what else to do.
09-02-2019 19:52
09-02-2019 19:52
I just shutoff my Fitbit and it was fine after restarting then it paired and started working again
Best Answer09-03-2019 01:42
09-03-2019 01:42
Hi @NKay14 What phone are you using? Is it on the Supported Devices List
Try all the suggestions in THIS Help Article on syncimg problems
Helen | Western Australia
09-03-2019 03:54
09-03-2019 03:54
Best Answer09-03-2019 05:48
09-03-2019 05:48
As you are in contact with the Support Team, carry on working with them.
