Fitness club workouts
How do you track your workouts at a gym? Like using the machines to work on the abs, or elliptical machines.  What app do you use.  Would I use the 'Workout' tab on the exercise app that comes with the Versa?
2 REPLIES 2
If it not listed then yes use Workout mode.
If i do treadmill/Elliptical I use that. But if in going to switch between the weight machines I use workout mode
Should add I spend 30 minutes on elliptical or treadmill before I switch over to weight machines.  If you are moving back and forth  between both Then I would use workout mode. Doing the elliptical or treadmill for 30 minutes use that. When you switch to machines then use workout mode
Community Council Member
Wendy | CA | Moto G6 Android
Thanks Wendy.  So are you saying you use the Treadmill section for elliptical also?
Also, do you know what the Interval Timer is?
