05-28-2018 10:02
05-28-2018 10:02
I have the honor 10 and have been fuming as it wouldnt sync at all. It was becoming a pain in the end and fitbit were no help at all
I tried all the tips they tell you to but to no avail but have found one myself
Go to settings
System and reset settings
Reset network settings
This completely resets the bluetooth and its worked for me... Been on for over 24 hours now. Id have been lucky to get it to work for 24 seconds before
Hope it can help others
11-25-2018 16:32
11-25-2018 16:32
Try emailing the developer at the bottom of the app. I had to do that once and he was responsive.
Best Answer11-25-2018 17:57
11-25-2018 17:57
11-26-2018 00:48
11-26-2018 00:48
11-26-2018 06:27
11-26-2018 06:27
Great. Mines not working this morning.....
Best Answer11-26-2018 11:37
11-26-2018 11:37
11-26-2018 11:41
11-26-2018 11:41
Awww thank you so much @themargot80. I contacted the developer and he answered me and we are hopefully going to resolve this. Have a great stepping day!
Best Answer11-27-2018 01:14
11-27-2018 01:14
Unfortunately, the 'fix' doesn't appear to be working for me. The Versa doesn't sync with my honor view 10 and I have never received a notification.. Not really the fault of the developer though .
I'm seriously considering sending the Versa back with all these issues after 2 days of use.
Best Answer11-27-2018 02:56
11-27-2018 02:56
@nsign7. Yes unfortunately it is the fault of Fitbit. They know about the problem and decide to do nothing.... The moderaters watch this sight but don't help out, they simply tell you to uninstall and reinstall... Sorry for your troubles.
11-27-2018 03:11 - edited 11-27-2018 03:14
Thanks Karona218,
It's a shame. I previously had a Blaze which was better at syncing with my View 10 so it's rather strange that newer versions don't have the same compatibility. Don't have any issues syncing with my work Samsung s8
Anyway hoping that the developer of the sync fix may be able to help with our issues.. I'd be happy to purchase the unlocked version if I can get a period of stability.. 😊
Best Answer11-28-2018 01:58
11-28-2018 01:58
11-28-2018 03:01
11-28-2018 03:01
@themargot80 . Hey I emailed the developer and he pushed out a new update to me of the app and we are working perfectly again!!!! Love that guy! I wonder if he knows how much we appreciate him? Lol. Have a great day!
Best Answer11-28-2018 03:22
11-28-2018 03:22
So what version of the app do you have. 0.5.2 is the version on the play store Do you have a newer version?
11-28-2018 03:32
11-28-2018 03:32
11-28-2018 15:04
11-28-2018 15:04
@nsign7 . That is the newest version. Yes.
Best Answer12-01-2018 00:36
12-01-2018 00:36
Thank you SO MUCH Czandor! I no longer have ANY issues with my syncing!
12-26-2018 05:04
12-26-2018 13:20
12-26-2018 13:20
Got my Versa for Christmas and it synced with my Huawei P20 straight away with no problems!!! Merry Christmas all 😘😘😘😘
12-26-2018 16:34
12-26-2018 16:34
Is this with using the sync fix app? Or did it just sync on its own.? Would be nice if Fitbit got on the ball and fixed the issue.
Best Answer12-29-2018 03:39
12-29-2018 03:39
Sorry, but your box should state that fact very clearly, so that there is no surprise for the users , I have huawei mate 10 lite and i am facing severe connectivity issues , and your excuse about comparability is not at all accepted.
Best Answer12-29-2018 05:58
12-29-2018 05:58
No sync fix required! Just logged on and off it went! Love it!
