07-24-2022
07:31
17:44
07-24-2022
07:31
17:44
I have meters and km in the app settings (always has) and now suddenly the clock and app shows speed in foot and inches. Distance is in km though. Any suggestion what to do?
07-24-2022 12:55 - edited 07-25-2022 06:27
Hello @Sussie74 and welcome to the Community. It’s hard to even guess above the clock issue. Is it a Fitbit clock or a third party clock? Can you add a picture so we can get a better idea of what you mean? Also, there is an issue with the Swedish language version of the iOS app where pace is being reported in feet and inches instead of minutes and seconds. Is this your other issue? If so, Fitbit is aware of it.
Laurie | Maryland
Best Answer07-24-2022 23:48
07-24-2022 23:48
Thank you for answering.
Sorry, I thought I posted to a fitbit versa 3 channel in the community so thats why I didn’t mentioned which clock I have.
Yes that is exactly my problem. So then I assume I only have to wait until they fix it.
Again thanks!
Best Answer07-25-2022 01:11
07-25-2022 01:11
I have the same issue.
Best Answer08-03-2022 11:31
08-03-2022 11:31
When will the issues with the Swedish language version be solved? My watch still shows foot instead of km.
Best Answer08-03-2022 12:27
08-03-2022 12:27
As @LZeeW mentioned this is a known issue being discussed here: https://community.fitbit.com/t5/iOS-App/Swedish-app-shows-incorrect-units-for-pace/td-p/5177098
