06-24-2018
14:52
09:26
AlejandraFitbit
06-24-2018
14:52
09:26
AlejandraFitbit
My Versa screen is frozen on source output screen.
03-22-2019 12:00
03-22-2019 12:00
Ive had such problems with my Versa...Support said do a Factory reset...I've done this...and now the watch face is frozen. None of the buttons work so can't do a restart....did you sort yours out?
03-22-2019 12:05
03-22-2019 12:05
Mine froze after doing the factory reset.
06-23-2019 09:41
06-23-2019 09:41
Used my versa at spa in pool today and now stuck and won’t end exercise
Ive synced it with the app but still stuck
06-24-2019 06:57
06-24-2019 06:57
@SueRoo22 thank you for participating in our Fitbit Community! I'm happy to assist you with your Fitbit Versa since the screen got stuck.
If you haven't done so, please restart your Versa as described in this help article. This will refresh your Versa internally. After this, monitor your watch's behavior and see if the issue gets fixed.
Keep me posted on the outcome!
10-24-2019 10:27
10-24-2019 10:27
10-24-2019 10:38
10-24-2019 10:38
12-19-2019 04:22
12-19-2019 04:22
I'm having the same problem. I've reset it multiple times and it's not fixing the problem.
01-22-2020 06:05
01-22-2020 06:05
I have done the reset several times and nothing works. My fitbit was working perfectly fine and then all of a sudden this black and purple (source/output) screen came up and it will not do anything else. I can't swipe right, left, up or down and the clock face never comes up.
01-22-2020 06:34
01-22-2020 06:34
Hi Jogger....Mine eventually sorted itself out....all very strange...and annoying! I would get on to Support...I have had 2 new Versas now...they only seem to go a time & then the black screen appears!!
01-27-2020 02:19
01-27-2020 02:19
My screen was frozen and I just held the button on the left forc a few seconds. It restarted and works fine now.
01-27-2020 02:22
01-27-2020 02:22
My screen was frozen on the source too. I just held the button on the left for 10 seconds and it restarted. So far no problems.
01-27-2020 03:52
01-27-2020 03:52
02-10-2020 02:33
02-10-2020 02:33
How do I reset my new Fitbit versa 2
03-10-2020 06:20
03-10-2020 06:20
@JuanJoFitbit my Versa2 screen regularly (it did not used to do this) freezes where I can click the button to being up the clockface but no swipe will work. I do a full reset and then it works again. Hours later, it will freeze again and I have to reset again, very annoying. That combined with the really bad syncing of some apps (especially the Weather app) makes this "smart watch" a very expensive "dumb watch"
