Getting Versa 2 out of charger
Having trouble getting Versa 2  out of charger
1 REPLY 1
Hello @3sullivan
If I understand your question correctly it sounds like you are saying your Versa 2 is stuck on charging mode. If so just press down and hold the button on the Versa 2 until you see the Fitbit Logi then release the button. You should feel the Versa 2 vibrate letting you know the restart is complete.
If you mean that it’s literally stuck in the charger and you can’t remove the Versa 2 from its charger just squeeze the two sides of your charger and that should release it.
😃Please let me know if this did indeed resolve the issue and provided you with the answer you were seeking.
