Getting "Notification service is not running"
Help! No matter what I do i can't get notifications on my fitbit versa 2. I'm starting to think it's my phone. I have a huwaei p30 pro. Any suggestions? Thank you 🙌🏽
12 REPLIES 12
Hi, your phone is on the compatible list, so not your phone, though may be a setting on your cannot be ruled out.
Just to be sure you are setup right check here
In the phone Fitbit App
Click on profile photo [top left]
Device photo [middle left]
Notifications
And verify the top 4 items are correctly defined.
Also
App notifications
and select any apps you want to hear from.
And to be sure your phone is properly synced, check here
Sync -
See when last synced
Try refresh by touching circle
it should say "a moment ago"
Thank you, I appreciate you taking the time to reply. Unfortunately I've tried all the options you mentioned and still no joy. Nevermind the notifications are just a luxury I suppose. I'm definitely going back to apple after this though!
Thank you for the feedback,  I appreciate it too.
Your issue is odd, I shall raise it to the next level.
I am having the same problem! I'm ready to pull my hair out!
Hi again, not sure if this will help you, but I just found in my watch settings that sleep mode was turned on! I know when I'm in the shower the water hits all kinds of settings. I've turned it off and now my notifications are back on
Thanks for the tip. I have checked sleep mode and it's turned off. I just keep getting the same message. It says notification service not running. A phone restart is required to re-enable notifications on your tracker. Yet when I do this it makes no difference! 😫🤯🙈
I keep getting the same message. notification service not running. A phone restart is required to re-enable notifications on your tracker. When I do this nothing changes I still cant get notifications! 😭🤯
@AliP76 @MichelleW22 Hi there. Thanks for the details mentioned and the troubleshooting performed.
If you've previously checked that all your settings have been properly set in your Fitbit app and Versa 2 but you keep receiving this error message. Let me tell you that we're aware of it and are working to identify a resolution as quickly as possible. We're sorry for any trouble. We appreciate your patience and look forward to getting you back on track.
@Guy_ Hi there. Thanks for the assistance provided in the thread.
I'll be around if you have any additional questions.
I received an update to the Fitbit app from the play store this morning, am on version 3.361 now.
Don't know if the fix is already in that version.
Check play store in case you don't have the latest version.
I uninstalled the fitbit app and then reinstalled it again. It's now on the latest version. The message about restarting my phone to receive notifications has now gone. Still not getting notifications though. 🤷🏽‍:male_sign:
Thank you 🙌🏽
I have a same problem. Doesn't metter what I do, it's just not working for me.
