10-24-2022
20:17
09:33
AndreaFitbit
10-24-2022
20:17
09:33
AndreaFitbit
I’m having a problem with my versa 2 green light, it is not flashing anymore and not tracking my heart rate, I’ve tried everything, resetting my watch and going onto the heart rate settings on my tracker, nothing is working, is there anything else I can try?
11-26-2022 05:53
11-26-2022 05:53
Thanks for getting back to us and letting us know about the readings you have gotten on your Versa 2 @polliewog14.
I understand how frustrating this could be and went ahead and created a case on your behalf and a customer support representative will contact you soon.
Have a nice day.
10-25-2022 09:38
10-25-2022 09:38
Welcome to the Fitbit Community, @Mimi123000. I'm sorry to hear your Versa 2 is not flashing the green lights and not tracking your heart rate.
Please see our heart-rate tracking troubleshooting steps on: What factors can affect my heart-rate reading on my Fitbit device?
Let me know how it goes.
10-25-2022 10:48 - edited 10-26-2022 06:09
Typical things to do are:
Don’t mess with the app yet as if there is no flashing green light on the watch the issue is there. Absolute worst case you can try a factory reset on the watch (just delete it from the app first) and then re-pair it.
Best Answer11-16-2022 15:34
11-16-2022 15:34
Interested if you got your green light working again. I’m having the same problem, but nothing has worked and it won’t download update. Keeps going through the motions and then offers the update again
Best Answer11-16-2022 21:14
11-16-2022 21:14
I haven't had a full week worth of heart rate readings since mid September. I get maybe one or two random days a week. Which means I also don't get sleep info.
I've tried all of the advice I've found throughout the forum posts, including a factory reset, and still nothing.
11-17-2022 00:06
11-17-2022 00:06
That’s mine too except I have had absolutely no heart rate or sleep data from September. Just waiting on it stopping completely so I can buy a new watch 👍
Best Answer11-17-2022 05:06
11-17-2022 05:06
Thank you for your advise @SunsetRunner and welcome to the Fitbit Community, @LINDSTAIR, @polliewog14. I appreciate the troubleshooting steps you have followed in order to get your Versa 2 green lights working again.
@LINDSTAIR, which update offer you get?
@polliewog14, did you try the factory reset from your watch or you followed the steps to do it manually?
I'll be waiting for your response.
11-17-2022 08:20
11-17-2022 08:20
There wasn’t a number on the update
Today I have tried the Factory reset and I think I have probably wrecked my Fitbit
All I have on watch screen is a red :cross_mark: says Data not cleared Sync and try again
I have been trying for hours 🤦🏻:female_sign:
Best Answer11-17-2022 08:58
11-17-2022 08:58
Help now I have lost the steps
Best Answer11-17-2022 12:20
11-17-2022 12:20
Thanks for getting back to us and for letting us know about the message that your Versa 2 shows after following factory reset steps @LINDSTAIR.
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
With that being said, please confirm if you've followed the steps below to solve this issue:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
I hope this information helps.
11-17-2022 15:25
11-17-2022 15:25
Definitely fearing the worst. Have unpaired, removed Fitbit app, turned phone off
still nothing except the red x and the same message. Is there any hope?
Best Answer11-22-2022 06:59
11-22-2022 06:59
Thanks for getting back to us and for following advised troubleshooting steps @LINDSTAIR.
I understand how frustrating this could be and could you please confirm that you have followed all the steps of my previous post?
I´ll be waiting for your response.
11-22-2022 09:03
11-22-2022 09:03
Hi, did all you suggested Thanks
I finally got my Fitbit to connect to phone again. It’s counting steps. Green light not flashing. Have noticed it’s not holding the charge as long, needing to charge every night now instead of 3 to 4 days. Still showing on App as update available but it won’t update. Have tried dozens of times
Best Answer11-23-2022 08:31
11-23-2022 08:31
Thanks for getting back to us and for updating us about the status of your Versa 2 @LINDSTAIR.
Could you please confirm that you have followed the steps of: Why can't I update my Fitbit device?
11-26-2022 04:38 - edited 11-26-2022 04:40
@AndreaFitbit I did the factory reset from the settings on the watch after first unpairing it from my phone.
I get very sporadic readings maybe once every 2 weeks. The last was from about 6am-8am Thanksgiving morning. Before that, I again had some random readings on Nov 14.
At this point I don't think that it's a software problem.
Best Answer11-26-2022 05:53
11-26-2022 05:53
Have a nice day.
04-20-2023 12:03
04-20-2023 12:03
Hi,
I'm having the same issue, no green light, no red light. I did 10 resets, 10 times switching heart on/off with sync...still nothing.
How can I get my watch repair?
04-20-2023 12:23
04-20-2023 12:23
Welcome to the Fitbit Community, @Nick32. I´m sorry to hear that your Versa 2 doesn´t have green light, red light and thank you for letting me know that you did 10 resets and switched heart rate on/off those times.
Could you please confirm that you have checked the help article on this post in order to correct this sitution.
Best Answer04-20-2023 12:51
04-20-2023 12:51
I did the shutdown, I did the unpair/pair, I did the factory reset and the last update I have is 35.72.1.23
Thank you
Nicolas
Best Answer04-20-2023 13:09
04-20-2023 13:09
Thanks for getting back to us and for mentioning the steps you have followed in order to get the green lights back on your Versa 2 @Nick32.
I went ahead and created a case on your behalf.
You can check your email.
