05-24-2020
11:39
06:28
JuanJoFitbit
05-24-2020
11:39
06:28
JuanJoFitbit
Over the past week I've had a few instances where my versa 2 has a green, slightly flickering screen. It has resolved itself within around 10-20 minutes. Today it has had a green screen for around 7 hours but was working fine earlier. If I hold down the button to restart it then it vibrates but nothing changes. I obviously can't do a factory reset on the device because I can't use the screen.
It's on firmware version 35.70.7.21 I've had no notification for updating the firmware. I am using the latest version of the app on my samsung s7 phone.
Any suggestions to fix would be appreciated. I bought it off amazon when it first came out and up to now I've been happy with it.
01-13-2022 15:46
01-13-2022 15:46
I’m on my third Versa 2 in two years. I had the first one a year and it went green. I thought it was something I did, so I purchased a new one. 6 months later, it went green. I contacted Fitbit and they replaced it. It has been maybe 5months and this one is green. Contacted Fitbit and they opened up a case for me. I’m done! I REFUSE to waste any more $$$ or time with Fitbit!!
01-13-2022 16:00
01-13-2022 16:00
01-14-2022 11:24
01-14-2022 11:24
01-15-2022 02:21
01-15-2022 02:21
That’s terrible , I’ve had a few Fitbit’s myself and this is the first time it’s happened to me and I must say the Fitbit support has been shocking to say the least they want me to send back to them and they will try and fix will be 3 + weeks !! This is after over a week of contact, plus I can’t be without watch for 3 weeks +.
After reading everyone’s comments and Google reviews I won’t be upgrading to the sense will go a different route now whilst I await the outcome of this, which is unfortunate as prior to this I’ve always rated Fitbit , thanks for your reply
Best Answer01-15-2022 06:19
01-15-2022 06:19
Fitbit did email me. They are sending me a replacement. This is FitBit Versa 2 number 4. I’ll wear it, but if it goes “green screen”, I’m going to switch to Apple.
Best Answer01-15-2022 07:29
01-15-2022 07:29
Update:
I let the battery total drain and left off charge for over a day. Got my screen back but functionality is still screwed up. Won’t let me go to screen with workouts and doesn’t record steps. Like I said- I will not buy another. Apple Watch is now going to replace it bc my daughter hasn’t had any issues with her Apple Watch
Best Answer06-08-2022 18:09
06-08-2022 18:09
Hello I have the same issue with mine. If you don’t mind could you disguise me as to what to do, how did you resolve this issue?
thanks
ptooke
Best Answer06-08-2022 18:10
06-08-2022 18:10
Hello
I have the same issue with my versa 2 (green screen/flickering. Will you advise please?
thanks
ptooke
06-08-2022 19:29
06-08-2022 19:29
06-08-2022 20:53
06-08-2022 20:53
Nothing can be done to reboot the watch
I had two watches go to green screen. One was still under warranty and was replaced.. I'll not buy another fitbit watch
06-09-2022 09:21
06-09-2022 09:21
I contacted Fitbit and told them that I was finished with the Versa and I was going with Apple. They sent me another replacement anyway. A month later my spouse bought me a Sense, so the Versa is sitting in some drawer.
Best Answer06-09-2022 12:59
06-09-2022 12:59
Best Answer06-15-2022 03:20
06-15-2022 03:20
Best Answer01-20-2023 07:12
01-20-2023 07:12
I bought mine used as well. It stopped working in 2 weeks. No warranty.
Best Answer01-20-2023 07:18
01-20-2023 07:18
I bought my Versa 2 on EBay auction. It worked for two weeks then quit because of a green screen. My money got blown on it. How can I fix it?
Best Answer01-20-2023 07:28
01-20-2023 07:28
I've had 2 fitbit versa with the green screen. There's no way to fix it. Both were under warranty and were replaced. I would not recommend buying another fitbit watch.
01-20-2023 14:49
01-20-2023 14:49
07-19-2023 23:27
07-19-2023 23:27
Same here. I let it sit in the box a few times. I thought I'd give it another go. In my case, I can see something on the green screen at times, it's faint but I see the logo and how much it's charged up. It appears to continue with a scrolling green screen. Then it looks like it's dead. Then I tap the front a few times and it kind of comes back on for a bit and then looks dead again. I am so bummed.
