03-18-2024 10:09
03-18-2024 10:09
Hi
I have read all the other post and followed the instructions, holding the button for ten seconds, trying to change the clock face ( it won't detect) my Fitbit so that's not possible.
Screen yesterday was black and then would show the fit bit symbol for a few seconds then go off
Today I have a green screen with lines all over like a broken alien tv it only shows for a few seconds then goes back to black
Any advice on what I can do at all, literally lost without it 😭
Thanks
03-18-2024 10:15
03-18-2024 10:15
Unfortunately it sounds like yet another dead FitBit device... I think your only hope is that it's still under warranty and you can try to get a new one 😪
03-18-2024 19:57
03-18-2024 19:57
I was dreading that answer 😭 how do I even find out if it's still in warranty 🤣
03-22-2024 06:31 - edited 03-22-2024 06:40
@J01988 ... You're probably going to have to try and contact FitBit support which can be a real challenge these days.
I've decided to get rid of my FitBit Charge and now use a competitor's product which I really like. That said I also have a first generation FitBit Aria scale that I purchased years ago and it still works (although it tells me I'm "overweight" 🤣🤣🤣) so I continue to use it. That said if it continues to tell me I'm fat, then I might toss it out as well!!! LOL 😆
