02-19-2019 15:10 - edited 02-20-2019 11:49
Fitbit Update: 2/19/19
Hi Versa Fam!
We're aware of an issue where some of you may be experiencing issues with your Versa no longer tracking heart rate (HR) and the lights below on the sensor don't flash.
If you come across this problem, please give the watch a restart. We suggest charging the watch to a full battery and monitoring the HR behavior afterward.
Just to make sure we have all the bases covered, double-check that you have Heart Rate turned "On" under the Settings app.
If your watch still isn't recording your HR, please let us know and we'll connect you with our Customer Support team.
Thanks for your troubleshooting efforts! We'll be around if you need us.
02-24-2019 18:18
02-24-2019 18:18
Heart rate is actually turned ON or OFF under the Versa device settings.
02-25-2019 06:11
02-25-2019 06:11
@Bonch22 Welcome to our Fitbit Community! I'm sorry for the late response. However, I was able to get in touch with our Support team and was told that they sent you an email with some instructions. Was a solution provided?
@CRow123 I'm so glad to hear that your Versa is working properly now. Thank you for posting the update here.
@Coopaspop @Stacyrenee I'm so sorry to hear about the issue you guys experienced with your Versa trackers. However, I'm so glad to hear that you were sent replacement trackers for each of you. Don't hesitate to get back if you need further assistance.
@EmmaSpade It's great to see you in our Fitbit Community! I'm sorry to hear that your Versa is not tracking your heart rate nor sleep even though you have restarted it and re-set it up before contacting our forums. I would like to follow up and would like to know if the issue persists or if your sleep and heart rate is being tracked again.
@uaustin Thank you for participating in our Fitbit Community! I'm sorry to hear that your Versa stopped tracking your heart rate and sleep also. Thank you by the way, for restarting your tracker as advised before. Since the issue persists, I'll send your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
@JasiaP I'm so glad to hear that the restart process helped you to fix the issue that your Versa was experiencing. Thank you for posting the update here.
@Naivety Thank you for joining us in this thread! I'm sorry to hear that your Versa is also having a hard time to track your heart rate properly. Due to this, let me go ahead and send your case to our Support team so they can follow up and assist you further. Please keep an eye on your email account.
@littlehappy I'm sorry to hear that your Versa is still unable to track your heart rate properly even though you've followed the troubleshooting steps that recommended our Support team. I was able to get in touch with them and was told that they'll follow up via email soon. Let me know how it goes.
@Pokely Welcome to our Fitbit Community! Thank you so much for sharing this information. In order to avoid any confusion on my end, please let me know if you are experiencing issues with your Versa.
See you all around!
02-25-2019 08:20
02-25-2019 08:20
02-25-2019 09:55
02-25-2019 09:55
02-25-2019 10:47
02-25-2019 10:47
Is there something going on with ALL of our Versas?! Mine stopped monitoring my HR last Thursday.
02-25-2019 10:49
02-25-2019 10:49
02-25-2019 15:04
02-25-2019 15:04
My Fitbit isn’t tracking my HR, my Active minutes, my sleep, not green light flashing at all plus doesn’t sync my steps in the challenges. I already uninstalled the app and installed again, I have restarted the watch and the phone, ..... nothing is working ...... my Fitbit doesn’t track HR or any of the stats mentioned before since Friday 22nd Feb. I don’t know what else I can do to fix it!!!!!
02-25-2019 20:10
02-25-2019 20:10
I restart my fitbit three times, still not recording my HR & green LED lights is not coming on. HR setting is turned ON.
What do I do next?
02-25-2019 22:40
02-25-2019 22:40
I've tried following steps:
02-26-2019 04:44
02-26-2019 04:44
I chatted with a representative yesterday, manual reset and factory reset and still no HR. I had just charged it that morning and the battery drained by the evening. The Versa was fully charged by bedtime so I figured I’d sleep with it on to see if that helped HR. I woke up less than 8 hours later to an unresponsive Versa.
02-26-2019 12:07
02-26-2019 12:07
@Azahaara @Pop243 @ETabben @Chgogrl Welcome to the Fitbit Community! I hope you're doing well!
Sorry to hear that your Versa isn't tracking your heart rate.
@ChgogrlPlease try a restart your Versa and see if this helps resolve the issue.
@Azahaara @Pop243 @Bonch22 since the issue persist the best thing to do is letting our Support team know so they can further assist you. @Azahaara you will get an email from them. @Pop243 @Bonch22 I noticed that you already have a ticket with them so I wanted to know if they were able to help you?
@Pokely happy to hear that your Versa is working now.
@Coopaspop thank you for your help here.
Let me know how it goes!
02-26-2019 12:37
02-26-2019 12:37
Just curious, if there is a known issues with things like this, are there not ways to notify the community or fitbit users? I only found out AFTER my workout with no HR reading.
02-26-2019 17:57
02-26-2019 17:57
@AlvaroFitbit I did not receive any response to my ticket from the support team.
02-26-2019 17:58
02-26-2019 17:58
02-27-2019 10:41
02-27-2019 10:41
My HR on my Versa is on and I have restarted my Versa but still no heart rate is showing on my Versa.
02-27-2019 18:32
02-27-2019 18:32
I am having the same issues with the HR not tracking. It worked fine until this morning. This Fitbit is only 2 months old. I have restarted the device several times and toggeled on and off in settings and nothing is working. This is frustrating because I just bought this at $200. Anyone know how to fix this?
02-27-2019 19:43
02-27-2019 19:43
02-27-2019 19:45
02-27-2019 19:45
02-27-2019 20:43
02-27-2019 20:43
02-28-2019 15:33
02-28-2019 15:33
My Versa is doing the same thing for the past week. I have already completed a factory restore, made sure the monitor is on, not off and still no lights or heart rate.
