02-19-2019 15:10 - edited 02-20-2019 11:49
Fitbit Update: 2/19/19
Hi Versa Fam!
We're aware of an issue where some of you may be experiencing issues with your Versa no longer tracking heart rate (HR) and the lights below on the sensor don't flash.
If you come across this problem, please give the watch a restart. We suggest charging the watch to a full battery and monitoring the HR behavior afterward.
Just to make sure we have all the bases covered, double-check that you have Heart Rate turned "On" under the Settings app.
If your watch still isn't recording your HR, please let us know and we'll connect you with our Customer Support team.
Thanks for your troubleshooting efforts! We'll be around if you need us.
02-12-2019
02:23
05:19
FerdinandFitbit
02-12-2019
02:23
05:19
FerdinandFitbit
Hi: My Versa dashboard was tracking sleep normally up to last Friday morning - but not a thing since then. The dashboard syncs normally for steps etc - but the sleep tile just sits there blankly. Is there some way of persuading it to come alive again????
Moderator edit: Updated title for clarity
02-12-2019 03:43
02-12-2019 03:43
Hi @Willy37 and welcome to the forums. Which OS are you using to view your dashboard? Android, iOS, or Windows? This will help narrow the source of the problem.
Laurie | Maryland
Best Answer02-12-2019 03:44
02-12-2019 03:44
Good afternoon,
I have bought my Fitbit Versa last year in May in Singapore and last week I have noticed that it doesn't record my heart rate. I have checked and I have one of the sensors on the back missing - attached picture.
I would like to know if that can be replaced / repaired and if that is still under warranty (and what I need to claim that).
Thank you in advance
Best Answer02-12-2019 03:45
02-12-2019 03:45
I'm having the same issue with my android. No heart rate either
Best Answer02-12-2019 03:52
02-12-2019 03:52
Best Answer02-12-2019 03:55
02-12-2019 03:55
Having the same issue. Using an Android device. It still syncs my steps but heart rate and sleep monitoring are not working. Checked via Google Play if an update was missed but that is not the case.
Best Answer02-12-2019 03:58
02-12-2019 03:58
My husbands Versa has stopped tracking heart rate and sleep since 6am yesterday morning. He is using IOS. He mentioned a recent update. It happened when he put it on the charger yesterday morning.
Best Answer02-12-2019 03:59
02-12-2019 03:59
02-12-2019 04:40
02-12-2019 04:40
Hi, same here. No tracking of sleep and heart rate since Sunday I think. On the backside of the Versa only 2 red lights in stead of 3. Hope it is only a error in the update. Worriesome, though
02-12-2019 04:43
02-12-2019 04:43
02-12-2019 05:07
02-12-2019 05:07
Best Answer02-12-2019 05:40 - edited 02-12-2019 05:41
My Versa has really been going downhill lately. It was working reasonably well since I bought it last spring ($200), but more and more in recent weeks, it decides to arbitrarily stop tracking things like sleep 1-2 times a week now.
If I completely delete the Versa device from the Android app and then reconnect, it seems to start tracking sleep again, but this is a PITA to keep doing since I have to reset all the previous settings. Rebooting the phone and/or the Versa seems to work occasionally.
I assume it's a software issue since it's been working fine until recently. Now this Versa seems no longer worth it if I'm going to have to put so much time/effort in to online research to find fixes to keep it functioning.
Also, why don't these things self-diagnose? Why is it that we as users have to discover that the thing isn't working by the lack of data showing up one day? Shouldn't the developers add routines to periodically check if all the data is being sync'ed or detect that something's wrong, and at least recommend a user fix if not try to fix itself?
I would think this would be a much better UX than hiring robots to troll the message boards repeating the same PITA "fixes" over and over again to us paying users.
I'm leaning more and more towards spending the "premium" dollars on Apple products because my time is valuable too, and Fitbit doesn't seem to be be focused on UX as much as Apple.
02-12-2019
05:40
05:20
FerdinandFitbit
02-12-2019
05:40
05:20
FerdinandFitbit
Then the problem might be in the software and not in the Versa itself. That might be hopeful.
I tried re-installing. Didn't help. I am not happy. Maybe Apple .... But I really do love FitBit.
Moderator edit: Merged replies
02-12-2019 05:50
02-12-2019 05:50
Did a shutdown and restart, and was able to get the heart rate monitor back. Won't know if the sleep tracker will work until tonight.
Best Answer02-12-2019 05:54
02-12-2019 05:54
Did the shutdown , heart rate for about a minute. Then nothing again. Found the same problem talked about in other forums in this help section. I wonder why Fitbit doesn't give a notice. It seems a lot of Fitbit users are experiencing this problem.
02-12-2019 12:32
02-12-2019 12:32
Hello....please can you advise next steps. This started with the heart rate not being monitored and batter discharging in a matter of hours. I followed your instruction for factory reset and now the Fitbit is non-responsive and won’t come on. It’s 7 months old. This shouldn’t happen.
Best Answer02-12-2019 15:19
02-12-2019 15:19
@Viv44 yes, this should not happen. Rapid drain combined with other issues you mention would suggest software problem. I'm flagging your post for Customer Support assistance. They should get back to you shortly.
Best Answer02-12-2019 16:02
02-12-2019 16:02
@lencacz Welcome to the forum. Perhaps my eyes deceive me, but I cannot see anything missing. Are the sensor lights blinking? Please go to Settings app on your Versa (swiping left), tap it and scroll down to heart rate. Please toggle it ON and OFF with a reboot of versa in between. You can reboot your tracker by pressing and holding the left and bottom right buttons until Fitbit logo flashes. Also, make sure you're wearing Versa's band tight enough, and that Versa's battery is not critically low (anything between below 10-15) as the sensor may turn off automatically. I recommend toggling the heart rate settings ON/OFF, rebooting and placing on charger. Good luck!
02-13-2019 05:17
02-13-2019 05:17
Hi everyone! Good to see you all in the Fitbit Community Forums! 🙂
I'm sorry to hear that most of you are having problems with the heart rate on your tracker and sleep not being recorded. Thanks a lot for all your efforts in trying to get this fixed. I'd like to help you out!
I just checked and it seems that there are quite a few reports of this going on, so I'd recommend giving your Versa a quick restart in the meantime to see if you can get the heart rate monitor to work correctly again. and then, see if your sleep is being tracked correctly.
You can easily do this by pressing the left and lower right buttons for 10-12 seconds. This will make your tracker to reboot. After that, see how that goes and if you continue to have problems, let me know!
Keep an eye on the board for any update on this.
02-13-2019 05:47
02-13-2019 05:47
It totally worked! Thanks! 😁
