02-19-2019 15:10 - edited 02-20-2019 11:49
Fitbit Update: 2/19/19
Hi Versa Fam!
We're aware of an issue where some of you may be experiencing issues with your Versa no longer tracking heart rate (HR) and the lights below on the sensor don't flash.
If you come across this problem, please give the watch a restart. We suggest charging the watch to a full battery and monitoring the HR behavior afterward.
Just to make sure we have all the bases covered, double-check that you have Heart Rate turned "On" under the Settings app.
If your watch still isn't recording your HR, please let us know and we'll connect you with our Customer Support team.
Thanks for your troubleshooting efforts! We'll be around if you need us.
02-14-2019 15:04
02-14-2019 15:04
My heart rate numbers stopped as well....what is up? Cannot find answer.
02-14-2019 15:06
02-14-2019 15:06
My versa just started doing the same thing, no BPM registering and lights are not blinking on the back of the device.
02-14-2019 15:24
02-14-2019 15:24
My heart rate is not working anymore
02-14-2019 15:44 - last edited on 02-19-2019 08:35 by MarcoGFitbit
Mine heart beat stopped at 7+pm last night and still not working.Flashing lights not working either as said by others. Feel like I’ve tried everything except rebooting all over again
UPDATE:
Ok, I fixed mine by switching off and then on again.Press left hand button and bottom left at same time - wait until logo comes back on - a few seconds then go back on again- courtesy of a Fitbit help item
02-14-2019 17:13
02-14-2019 17:13
This worked!!! Thank you!!!
02-14-2019 17:46
02-14-2019 17:46
Thank you. That worked.
02-14-2019 19:01
02-14-2019 19:01
It didnt work on mine.
02-14-2019 19:33
02-14-2019 19:33
Same here it stopped working today
02-14-2019 19:55
02-14-2019 19:55
Turning it off and back on again worked Thanks
02-14-2019 19:57
02-14-2019 19:57
02-14-2019 20:50
02-14-2019 20:50
I'm having the same issue that just started today. What is going on? This is ridiculous, you spend all this money for a device and it doesn't work. Garbage!
02-14-2019 21:56
02-14-2019 21:56
Thank you it is now working you explained it better then the help site on Fitbit.
02-14-2019 22:06
02-14-2019 22:06
02-14-2019 22:59
02-14-2019 22:59
I’ve just recently had this issue and I’m not sure why
reads my heart rate and hen just stops period
won’t work until I re set my watch
Ive done this twice a day for the past three days
Is this a software issue or is my device faulty ?
Who can I send it to , to see if there is a fault in my watch ?
02-15-2019 01:32
02-15-2019 01:32
I have done this and mine still does not work. It stopped working on 13th.
02-15-2019 04:48
02-15-2019 04:48
Thanks for the thanks folks. I should also add that I lost my sleep data and a whole day of steps data when mine went down - anybody else ?
02-15-2019 05:00
02-15-2019 05:00
Me, too. Started yesterday.
02-15-2019 05:03
02-15-2019 05:03
That worked. Thanks.
02-15-2019 05:38
02-15-2019 05:38
Thank you! That worked for me.
02-15-2019 05:43
02-15-2019 05:43
That worked for me too. Thanks!
