06-10-2023
17:05
17:51
AndreaFitbit
06-10-2023
17:05
17:51
AndreaFitbit
HR stopped working on my Versa, after last iOS update!! Pleeease fix this very talked about issue!
06-10-2023 22:30
06-10-2023 22:30
Hi @Katsz1 - this may actually be a watch or clock face issue.
Try toggling the heart rate option in the watch settings - with it off restart the watch, then turn it on and restart again. This may fix it if it is a temporary issue but if you are experiencing other issues, short battery life, button or screen not working properly there can be a fault.
Heart rate is needed to detect sleep.
Try changing the clock face if the watch is syncing correctly but the information is not shown on the clock face properly.
In case of a syncing problem see Why won't my Fitbit device sync?
