08-24-2021 21:24 - last edited on 08-25-2021 13:09 by AndreaFitbit
Hi,
Weird thing happened tonight. My girlfriend and I both have Fitbit Versa 2 watches. We both had the Sp02 signature face clock on them. Suddenly, my girlfriend face clock changed automatically. Then, few minutes later, same issue on my watch. The face clock changed to a previous one I had long time ago. I tried re-installing the Sp02 signature face clock. It worked, but only for a few minutes. It auto-changed again. Also, it does not stay in the 5 preloaded one we can have on the watch. I am in a supported country (Canada) and I am not using a VPN which could have triggered that behavior.
I really wonder if this happened to anyone else. Sp02 signature is our favorite face clock and we wish to be able to put it on our watch again.
09-10-2021 17:32 - last edited on 10-26-2023 16:12 by MarreFitbit
Hi everyone.
Thanks for your participation in this thread, as well as your efforts while working on this matter. I understand how you're feeling about your watches changing the clock faces by themselves, and let me share that this issue has been resolved. Your patience is truly appreciated and please give a try to the following steps to make sure your Versa starts working correctly after installing any SpO2 clock face:
Hope this helps.
08-24-2021 21:27
08-24-2021 21:27
Same thing happened to me tonight, same face, same situation. Restarted a couple times, tried other fitbit watch faces, but keeps reverting to default watch face (which I do not like).
08-24-2021 21:42
08-24-2021 21:42
You're not the only one, same thing happened to me about 1/2 hour ago. There's another thread I posted in, which was started a couple of years ago, but someone woke it up about an hour ago. Here it is if you want to check it out:
Hopefully it just a glitch with the SpO2 watch face and they are working on it.
08-24-2021 23:14
08-24-2021 23:14
Seems to have started after I did the Fitbit Update. And yes. Happens every time I sync. I’ve been using the SpO2 face for quite a while now and it keeps going back to the default when I sync.
08-24-2021 23:50
08-24-2021 23:50
mine started doing the same thing today. I have been using the fitbit spo2 watch face for the past couple of months. This morning i woke up to find that i had a completely different watch face. I changed it back and about 30 min later it was again changed to the one i don't use.
08-25-2021 00:47 - last edited on 08-26-2021 10:39 by DavideFitbit
Is Fitbit going to fix this problem ASAP?
I see so many users describing the same problem: when using the Fitbit SpO2 clockface.
I have been using the SpO2 clockface for over a year. On Monday August 23 it started changing itself. I only have one clockface (SpO2) chosen in the Fitbit app...
Obviously Fitbit has pushed a buggy update out to users, and needs to fix this.
08-25-2021 00:56
08-25-2021 00:56
Happening to me as well.
08-25-2021 01:19
08-25-2021 01:19
Also happening to me on my sense since the update. I use the SpO2 Active watch face and it continually resets to the default.
I've also noticed the ECG app needs updating when the clock face changes back. Not sure if this is connected or not.
08-25-2021 01:23
08-25-2021 01:23
I've had the same issue with sp02 watch face! Every time it syncs it switches to default. So annoying!
08-25-2021 02:02
08-25-2021 02:02
This also started to happen to me this evening..
08-25-2021 02:05
08-25-2021 02:05
Agreed, is Fitbit going to fix the problem?. Totally blew my workout schedule this morning trying to figure this out. Very frustrating!
08-25-2021 02:10
08-25-2021 02:10
I'm having the same problem, my Sense switches to default when I try to get sp02 watch face back.
08-25-2021 02:38
08-25-2021 02:38
Had the same issue myself. With help from support chat on the fitbit website, we have a workaround. In the app, click on your avatar in the top right corner, then click on your watch (Versa 3 in my case), then click on Clock faces. Under my device, at the bottom of the page you should see My Clock Faces, with the clock faces you've installed previously. Select the one you want, and wait for it to install (you'll need to make sure bluetooth and preferably wifi are all connected on your watch and phone). Once that's installed, click on the other watch faces listed under My Clock Faces and uninstall them. You should now only have the face you want listed under My Watch Faces (in my case Sp02). Now, when the watch syncs, it shouldn't switch the face again. Works for me, hope it does for everyone else!
08-25-2021 02:44
08-25-2021 02:44
It appears to be fixed. There was a mini update a few minutes ago, and my clock face changed back to the SP02 face and it has stayed that way for about 15mins now.🤞
08-25-2021 03:07
08-25-2021 03:07
Yes, happened to me too for the first time today on my Fitbit Sense. My partner had been complaining about it a while on her Versa but it's the first time I've had the issue and only after moving to the Sp02 Active clock face.
This wasn't something that auto solved, however, when I opened the Fitbit app I noticed that I couldn't simply apply the clock face again - I had to download it.
I suspect that as part of Fitbits release process they are removing an old version and replacing it with a new version. Upon doing so, it is causing Fitbits to revert to the default settings, whilst you then download the new version and apply it back to the phone.
08-25-2021 03:20
08-25-2021 03:20
This is happening to me too. But started before I updated. (A few days ago.) I updated to see if it would solve the problem and 5 minutes later it reverted to the default clock face.
08-25-2021 06:17
08-25-2021 06:17
This just happened yesterday on my Versa 3 and it's also happened one time prior. The watch face on my fitbit is not always on and the buzz notification is felt on the wrist. The same type of notification if you have not met your hourly goals or received a text message. Then you look at the watch to see what the notification was and find out that the watch face has changed. In addition, all of your custom installed watch faces are gone. I've only used the fitbit created/authorized watch faces. Thus, the suggestion of only using only the "approved" watch faces is just another deflection.
Were you provided a true solution for the watch to keep the watch face that I select?
08-25-2021 06:55
08-25-2021 06:55
I think I may have fixed mine.
Go back into your watch faces and make sure the default watch face is installed, for me that is Waveform.
Then remove the SpO2 watch face from your saved watch faces - click on it and scroll down, there should be a button to remove it(you may have to remove all the saved ones except for the default - I only had the SpO2 saved).
Now go back into Watch faces and reinstall the SpO2 watch face - when it asks for permissions turn them on - they are defaulted to off. I turned them all on, if you leave them off your watch face will not show any of your stats, they will just be blank.
It's been about 45 minutes and everything is working again except for the Oxygen level and that's because it only updates while you sleep. Everything else, steps, heart beat, stairs and zone minutes are working. Good Luck.
08-25-2021 06:59
08-25-2021 06:59
I have done nothing since my issue about 8 hours ago. I think there might have been an update. I just put the sp02 face that I like and it has not changed for about 45 minutes. Will update if I notice something
08-25-2021 09:24
08-25-2021 09:24
Unfortunately that didn’t work for me. The SpO2 clock face is the only one I have installed. 😞
