04-29-2018
13:25
11:44
MarcoGFitbit
04-29-2018
13:25
11:44
MarcoGFitbit
Hi Everyone
I've just got the Fitbit versa and I have to admit that I am very frustrated. I have repeatedly tried to pair it with my iPhone 6s iOS 11.3.1 but it seems that the watch cannot be found. I also tried to reinstall the application and sign up with a new account but I still face the same issue.
I would appreciate if you could provide with some assistance.
Thank you in advance
Panos
03-12-2019 12:50
03-12-2019 12:50
Welcome to the Fitbit Community @EmmaLM96, @hfergy, and @Lydibug! I apologize for the delayed response and will be glad to assist you with your pairing Fitbit Versa with iPhone inquiry.
@EmmaLM96, have you been able to resolve your issue? Please turn OFF your phone's Bluetooth, restart your phone and try setting it up again.
@hfergy, thank you for your comments. If you bought your Fitbit at our store you can check the Return Policy and Warranty. Or your retailers specific policies.
Thank you for your feedback @Lydibug. Which Android device do you have? Please try @MarcoGFitbit's advise.
Let me know if you have more questions.
04-30-2019 17:53
04-30-2019 17:53
I've tried all of this and still can't get my Versa to pair with my iPhone 6s. I received the Versa as a Christmas gift, and months later, I still haven't used it. It pairs with my daughter's 6s, so I don't understand why it won't pair with mine. The Apple Store Genius ran a check on my phone and said the bluetooth works fine, plus I've had no trouble connecting with other bluetooth devices.
Help! How do I get support to solve this? I need it fixed before the end of May.
05-01-2019 07:31 - edited 05-01-2019 07:33
Welcome to the Fitbit Community @daugusta. I´ll be glad to assist you with your Versa syncing inquiry.
Thank you for letting us know that you´ve tried all advised troubleshoot steps and that it pairs with your daughter´s 6s and that you ran a check on your phone.
In order to assist you, could you please let me know if you have tried to connect other Bluetooth devices with your iPhone and could you try syncing your Versa with another device like a computer?
Let me know how it goes.
05-05-2019 18:22 - edited 05-05-2019 18:28
Two days of total frustration! Finally I came to your instructions and it worked! I had done everything but force quit the FitBit app. That did the trick! Thank you for your tech know how!
Follow these steps!
Thanks for sharing your experience with me and for letting me know you've already tried the troubleshooting steps to set up your Versa as a new device. As your watch is having trouble syncing, before trying to set it up as a new device, please try the following steps:
If your device still won't sync, try these steps:
05-06-2019 07:51
05-06-2019 07:51
Hello @vabuttercup thanks for joining the Fitbit Community, it's great to have you on board.
I appreciate your participation in the Forums and for sharing your experience. Thanks for letting us know the troubleshooting steps you've tried successfully, I'm glad your issue has now been resolved.
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
05-07-2019 01:37
05-07-2019 01:37
When I had problems with Bluetooth, the only way to fix it was to make my iPhone ‘forget’ my FitBit and then re-pair them.
05-07-2019 12:59
05-07-2019 12:59
Thank you for sharing what has worked for you @Prospector. Are you still experiencing pairing trouble with your Versa?
Keep on visiting the forums.
05-07-2019 13:03
05-07-2019 13:56
05-07-2019 13:56
Just one issue - the ‘previous track’ function on Music Controls (Bluetooth control of iPhone) has ceased to work recently. I have made a successful factory reset of my Versa and re-installed the FitBit app on my iPhone.
Also, the three dots feature ( ... ) under Music Controls is often unresponsive. It’s as though it needs a very precise point to be touched.
These are relatively minor issues, but disappointing none the less. Everything else seems to be working OK.
05-27-2019 13:13
05-27-2019 13:13
I lost Bluetooth on my FitBit Versa again last night. My iPhone Bluetooth settings page couldn’t detect the device.
I had to go to my account on the FitBit app, use ‘Remove This Versa’ and then add it again by using ‘Set Up a Device’. Frustrating!
...and the ‘previous track :fast_reverse_button: function still doesn’t work.
06-24-2019 14:39
06-24-2019 14:39
The ‘previous track’ function has been restored. No idea why. The only thing I have done is a few restarts of my Versa over the past few weeks (when it has stopped measuring heart rate).
07-12-2019 05:30
07-12-2019 05:30
Im also having the same issue I tried everything. iPhone 6s Plus ios 11.2
07-12-2019 05:40
07-12-2019 05:40
Im having the same issues I tried every thing mentioned above is still not working.
very frustrating. My versa did sync a while back, I’ve had sense December 2018 when it first came out it worked just fine and all of the sudden after trying to instañl the bitmoji it stop syncing and I also gave up on the bitmoji it didn’t work for me at all did not want to install regardless of everything I tried to do it just wasn’t syncing, ever sense my versa will not sync at all to my Fitbit app. Again I tried everything turn on and off my phone and the versa removing the app disconnecting all blue tooth devices, check for new software update.
It is very frustrating.
Please help
07-12-2019 05:48
07-12-2019 05:48
Hi Deya 22,
Have you tried making your ‘phone ‘forget’ your Versa on wi-fi & Bluetooth, then reconnecting? I think that worked for me last time.
Also make sure you don’t have the ‘phone in low power mode - that tripped me up a few times.
Hope you get it sorted.
08-06-2019 06:59
08-06-2019 06:59
Mines not an iPhone, but an Android. I moved to another state and ever since, it wouldn't sync. I did everything but it still doesn't work. It won't even find my tracker much less connect to my wifi. I can't even pair it via Bluetooth. My Charge never had problems...
09-08-2019 18:36
09-08-2019 18:36
Yes I was receiving message on my versa and for some reason my versa stop receiving message I do all the step but it still won’t pair
09-09-2019 04:20
09-09-2019 04:20
Hi,
I have troubles with my Versa not syncing normally with Huawei P 20 pro. I have tried all the troubleshooting suggested by Fitbit, but still have to delete the device from fitbit app and make factory reset, losing the data every three days. This makes the watch just useless.
The watch is still on warranty, is it possible to get a fixed one or should I just give up an return the watch for good?
Best Regards,
Valeria
09-12-2019 07:00
09-12-2019 07:00
I too have to re-sync my Fitbit Versa often. Today it won't sync at all. This thing is basically useless!
09-12-2019 07:43
09-12-2019 07:43
11-04-2019 10:26
11-04-2019 10:26
I have a Versa Lite that worked fine at first then started losing time then wouldn’t sync. Followed every step given to correct then deleted the device from the app and now I have nothing but the * download Fitbit app on the screen won’t connect to iPhone
