06-18-2018
12:54
06:30
HeydyF
06-18-2018
12:54
06:30
HeydyF
Headphones won't connect to my versa despite both being in pairing mode and multiple restarts of both versa and headphones just keeps coming up on versa saying no devices found! Tried everything suggested on here and still nothing! Very annoying!!!!
06-19-2018 06:30
06-19-2018 06:30
Hey @Cbeevr, welcome aboard! Let me ask you this, what type of headphones are you using? Can you pair them with another device like your phone, for example? In the meantime, please take a look at the following help article: How do I connect Bluetooth audio devices to my Fitbit watch? And let me know how it goes!
I'll be around!
06-19-2018 06:51
06-19-2018 06:51
Mine also. My headphones were working well then all of a sudden this weekend they stopped. I have removed them and then tried to add them back. Nothing. I have the Mpow Flame headphones. They work fine with my phone but I hate to take my phone with me so that is why I pay for Pandora so I can use my Fitbit instead. Now I can't do that. My Fitbit no longer can find the headphones.
06-20-2018 07:15
06-20-2018 07:15
Hey @Pwoo10, welcome aboard! Thanks for trying to unpair your Mpow Flame headphones and pair them again. Beside that, I'd like you to try to restart your Versa and then try to unpair and re pair them again.
Let me know if that works!
06-26-2018 05:45 - edited 06-26-2018 05:46
I did that and it didn't work. I now have 2 choices to either spend the expensive amount for the Fitbit brand headphones or cancel my $10 per month Pandora. I know the headphones pair with my phone and my laptop so they work just fine. They just don't pair with the Fitbit.
10-30-2018 04:39
10-30-2018 04:39
My Huwaei Sport Bluetooth headphones will not connect to my Versa. It comes up in the devices I can pair my Versa with and starts pairing. After about 2 minutes it says connection failed. I also tried to pair my friends Airpods and the same thing happened.
If you could tell me how to fix this issue it would be very helpful.
10-31-2018 06:17
10-31-2018 06:17
Hey @Bigspider, let me give you a warm welcome to the Community! I would suggest you to restart your Versa by following these instructions, then try to pair your Huawei Sport Bluetooth Headphones again. They should connect.
Let me know how it goes!
12-29-2018 12:25 - edited 12-29-2018 12:35
same issue here, I have jlab headphones, they connect fine to the phone. I restarted the watch and the headphones everything has a full charge, versa can't find the jlab headphones. finally after restarting both the watch and the headphones, I put the earbud in my ear and listened while I turned it on, had to hold in the button a 2nd time on the headphones then it said ready to pair. After that the versa was able to see it.
12-31-2018 06:17
12-31-2018 06:17
Hey @gotmoxie, welcome aboard! I appreciate you have taken the time to try some tips to connect your Jlab headhones with your Versa, sounds great that they get connected. Thanks for sharing your tips, I'm pretty sure that they will help other users with the same inconvenience, to solve it.
Let me know if you have further questions!
12-31-2018 06:38
12-31-2018 06:38
Finally got mine to work. When I followed the steps on the site, I could only connect 1 of the earbuds at a time (even though they were synced to each other) since the versa was detecting them as individuals. Don’t know, it was weird. Under the “audio device +” button there is a toggle to pair with phone. Mine was set to “off” I toggled it to “on”. Still didn’t work. Then I toggled it to “pair” and it worked. Maybe I overlooked something super obvious, but I didn’t remember seeing anything about that particular function in any of the setup instructions.
01-01-2019 05:09
01-01-2019 05:09
Hey @Mangoesrgreat, let me give you a warm welcome to the Community! I appreciate you have tried some tips to connect your headphones with your Versa. I'm pretty sure they will help other users with the same issue, to solve it. Now, let me ask you this, are both earbuds working fine?
I'll be around!
01-02-2019 09:41
01-02-2019 09:41
01-04-2019 04:54
01-04-2019 04:54
Thanks for your reply @Mangoesrgreat and the update! Sounds great that your headphones were connected with your Versa.
If you have further questions, let me know!
04-15-2020 11:35
04-15-2020 11:35
I found that I couldn’t have my earbuds paired with my other devices. Once I unpaired them, my versa found my earbuds
