11-02-2021
09:01
13:15
RodrigoMFitbit
11-02-2021
09:01
13:15
RodrigoMFitbit
I noticed this morning that my versa 2 is not picking my my heart rate. It looks like this started sometime Sunday. I'm hesitant to try a factory reset because last time I did that it was a problem with the update.
Best Answer11-03-2021 08:41
11-03-2021 08:41
After uninstalling the app and reinstalling and multiple restarts that did not work, I did end up doing a factory reset. This seems to have fixed the issue.
11-03-2021 08:41
11-03-2021 08:41
11-03-2021
17:40
08:56
11-03-2021
17:40
08:56
@coll2383 , nice to see you here. Thank you for your messages and efforts.
I marked your last reply as Best Answer so that other users know what helped you and can find the answer easier.
I appreciate you sharing all this .
See you around.
Best Answer11-22-2021 16:02
11-22-2021 16:02
This is the 2nd versa 2 i have had and the latest one worked well for about 3 months then it stopped giving me sleep data then stopped health metrics.
the support are useless asking me to do the same things as always , ive uninstalled my versa and reinstalled it , ive change the wrist its on , ive cleaned it and the green light blinks, im so dissapointed and feel sure that somethings changed as my first versa 2 was problem free for the couple of years I had it till it died.
can anyone tell me what to do apart from throwing it in the bin
