05-15-2020 00:01
05-15-2020 00:01
Hi, my heart monitor isn't working, any ideas how to start it again? I didn't wear my Fitbit versa2 for a few days due to RSI and the hear monitor hasn't worked since, it seems to effect other tracking updates too. I wear the fitbit on my right wrist and tried it on my left but with no joy. 🙄
05-15-2020 12:18
05-15-2020 12:18
I would first try swiping over to settings and check that heart rate is turned on.
Does the red light flash properly?
05-15-2020 17:52
05-15-2020 17:52
I have been having the same issue. I have restarted it and did the factory reset. It still won’t work.
05-16-2020 08:14
05-16-2020 08:14
@Abravo are your green lights flashing properly?
Is the heart rate enabled?
Have you tried a Hard reset by turning off the tracker?
Hold in the button or the left and lower right buttons to turn on.
