02-06-2020 16:34
02-06-2020 16:34
If i turned the heart rate tracker notification off on my tracker, will my sleep tracking be off?? Seeing my heart rate kind of freaks me out so I turned rhat function off and my sleep has been saying I sleep less then 4 hours a night which is crazy! Or do you think I am wearing to loose and low on my arm?
02-07-2020 13:37 - edited 02-07-2020 13:41
Welcome to the Fitbit Community, @Kerryberry2228.
I appreciate your participation in the Forums and sharing your concern on tracking sleep after you turned off your heart rate monitor. Thank you for providing the additional details, I totally understand how you are feeling. If you decided not to track your heart rate, you should see your sleep pattern in the Fitbit app. Your sleep pattern includes your time spent awake, restless, and asleep. You can see your sleep stages if you turn on your heart rate monitor.
Autodetection is based on your movement and I recommend doing the following:
It is possible to correct the sleep record from your dashboard by following the steps from this help article: How do I edit, or delete sleep logs in the Fitbit app?
You can find more information about tracking sleep here.
