11-23-2019 09:59
11-23-2019 09:59
I have been using Fitbits for many years and have had many Fitbit devices. I just bought the Vesa 2 in hopes that the heart rate monitor accuracy will be better on this latest and greatest from Fitbit. Sadly, I experience the same disappointing readings with my Versa 2 as I did with my other devices from Fitbit over the years. Due to medical reasons, I need to really track my heart rate during exercise. So I wear a chest strap heart monitor because that is always super accurate during exercise. When comparing my heart rate during workout from my chest strap and 3rd party app and my Fitbit, Fitbit is consistently off by being as much as 40 bpm lower than actual during my workout. Very disappointing. I understand that the optical heart rate monitor technology probably isn't as accurate as chest strap during intense activity. And yes, I have tried different positions on my arm, different levels of tightness with the band etc. I have tried everything imaginable with Fitbit devices to try and get accurate heart rate readings during intense exercise. I don't understand why Fitbit won't allow a 3rd party chest strap monitor to sync with Fitbit app, or 3rd party app to transfer over heart rate data or even to allow customers to manually enter heart rate data into Fitbit app, or maybe had an edit function where customers can edit the incorrect heart rate data. For comparison, Samsung Health allows for customers to connect a 3rd party chest strap. So you wear their wearable device all the time and your heart rate is constantly measured, but then you put on your synced chest strap monitor when working out. All data syncs perfectly with the Samsung Heath app. Perfect and easy. I don't understand why Fitbit doesn't allow such a workaround for their customers, especially if it is well known that optical heart rate monitors aren't very accurate during intense exercise, especially when there is lots of movement (burpees, shadow fighting, pushups, mountain climbers etc.). I keep hoping that Fitbit will announce an update that will allow this. Yet this hasn't happened to date and I continue to be disappointed. Not sure how much longer I will stay with Fitbit to be honest. How can you get an accurate picture of your overall health if you are forced to use an optical heart rate monitor that isn't accurate (not even close) during intense exercise? Even if Fitbit says they are considering letting heart rate data from 3rd party sources (device or app), I would be encouraged to hold on a bit longer. Even if they made this a premium feature that customers have to pay for, I'm in! Seriously take my money, it's that important. Here's hoping that changes are coming soon, or else I may sadly have to end my decade plus long relationship with Fitbit. Sad.
12-10-2019 05:17
12-10-2019 05:17
Hi - Thanks for the reply. None of these suggestions solved the issue. However, I was able to find a 3rd party armband for Fitbit Versa devices on Amazon. It is awesome! Holds the sensor nice and snug on the bicep and prevents the device from moving. Compared heart rate results to the chest strap monitor and results are only off by 2 - 4 bpm at certain points, and match exactly most of the time. That is a much more reasonable margin or error. Happy I found a solution!
12-03-2019 12:26
12-03-2019 12:26
@Scotty7991 Welcome to the Fitbit Community! It's great to have you here! Sorry for the delay in my reply.
Let me help you with your heart rate readings and suggestions and thank you for trying different positions for the heart rate accuracy. I suggest you clean the back of your device with cotton and rubbing alcohol and restart it. Turn the heart rate off, save and sync then turn it on save and sync again. Also check these tips to improve the heart rate reading on your device.
Regarding your suggestions you can share your idea in our Feature Suggestions board. Search for the idea first to see if one already exist so you can add your vote. The more votes an idea gets the more likely the developers will try to implement it.
Let me know how it goes.
12-10-2019 05:17
12-10-2019 05:17
02-21-2020 07:25
02-21-2020 07:25
I have the same problem. Could you share what that product you got from Amazon is please?
06-04-2020 08:37
06-04-2020 08:37
Hi! What was the name of the chest band you bought and does it still work?
06-04-2020 09:36
06-04-2020 09:36
