11-14-2018
09:26
11:33
HeydyF
11-14-2018
09:26
11:33
HeydyF
My versa heart rate is not working this fitbit is frustrating me!!
11-20-2018 06:14
11-20-2018 06:14
Thanks for your reply @DalRose68! Considering that you still experiencing the same issue with the heart rate sensor on your Versa, I have escalated your case with our Support team for them to further assist you.
Let me know how it goes!
Best Answer11-14-2018 15:15
11-14-2018 15:15
Hi, @DalRose68! I would suggest restarting your Fitbit a few times. You can do this by holding the left and bottom right buttons for about 10 seconds, until the Fitbit vibrates.
MakMak | Community Council
Best Answer11-14-2018 16:02
11-14-2018 16:02
@DalRose68 You also may want to explain in detail what is not working. "My versa heart rate is not working " is is too vague! Some examples/suggestions:
Best Answer11-14-2018 19:23
11-14-2018 19:23
Best Answer11-19-2018 11:37
11-19-2018 11:37
Hey @DalRose68, I hope you are doin' fine! If your Versa is showing this "--" instead of your BPM, I'd like you to turn OFF the heart rate monitor on your Versa, restart it and then turn it ON again. If after trying that, the issue persists, let me know and I will continue assisting you.
Thanks for your help guys @lenny4d and @MakMak
I'll be around!
11-19-2018 12:55
11-19-2018 12:55
@DalRose68 If you swipe up on the main Versa screen (this opens Today app) and scroll down a bit, can you see your heart rate there ?
Best Answer11-19-2018 21:18
11-19-2018 21:18
Best Answer11-20-2018 06:14
11-20-2018 06:14
