04-05-2020
19:57
17:47
DavideFitbit
04-05-2020
19:57
17:47
DavideFitbit
I would like to see my heart rate on the swimming data screen
04-06-2020 14:14 - edited 04-06-2020 14:15
@Normberg have you voted for the feature request? Your not the only one.
Heart Rate being monitored while in swim mode
Have you tested the tracker to see if the Fitbit is able to read a heart rate while swimming?
04-07-2020 09:25
04-07-2020 09:25
It’s a bit hard to swim right now. So the 2 pieces of data I need are a running clock with seconds and heart rate.
swimming or stopwatch has the clock. I down loaded the hr zones app. and can see he but not a clock
04-08-2020 13:34
04-08-2020 13:34
Hello @Normberg after you put your tracker into the Run mode. Seconds, down to the tenth, will be displayed at the bottom of the tracker.
Swipe left or right to put heart rate in the middle stat.
04-09-2020 09:35
04-09-2020 09:35
So are you suggesting I swim with the run mode selected?
04-09-2020 12:31
04-09-2020 12:31
If you want to test if the tracker can read the heart rate while swimming, then yes.
Some users that sweat a lot have already complained that they have to stop running and dry the arm and tracker off to get the heart rate to read.
