04-21-2018
09:22
11:42
RobertoME
04-21-2018
09:22
11:42
RobertoME
I just went on my first run with the Versa and found the heart rate wildly off. I've had several other Fitbit devices that have registered a peak rate between 160-165 bpm for the same run, on the same wrist, with the same wrist placement. This run shows a lengthy section where my heart rate peaks at 209. I'm in my late 40's... No way that is accurate. Anything I can do to fix this?
Moderator Edit: Updated Subject For Clarity.
11-05-2018 02:42
11-05-2018 02:42
I spent the day sitting at work on a phone and managed to burn 6500 calories.
HR jumps from 90 to 160 for no apparent reason.
Was there any possible solutions to this?
Best Answer11-05-2018 03:06
11-05-2018 03:06
11-05-2018 04:35
11-05-2018 04:35
Best Answer11-05-2018 13:26 - last edited on 10-24-2019 19:26 by LiliyaFitbit
Thank you I will try that.
I was also thinking of getting the $100 wriststrap to make it easier to
move the Versa up my arm.
Best Answer11-07-2018 04:17
11-07-2018 04:17
Their recommended placement may be suitable for people with straight forearms but it doesn't really help me. The Versa is kinked at a weird angle.
What is confusing is that it suddenly went from working fine 3 days ago to starting off reasonably accurate and then within 5 minutes off by almost 100%.
And support doesn't really help at all.
Best Answer11-07-2018 07:27
11-07-2018 07:27
Best Answer11-07-2018 07:47
11-07-2018 07:47
11-07-2018 08:13
11-07-2018 08:13
Best Answer12-04-2018 14:25
12-04-2018 14:25
Hi,
I thought it seemed off and google search brought me here. i am concerned because your post is from April and I just bought mine.
have they responded to you at all?
If it is taking this long, it probably won't be fixed???
My Charge 2 seemed more accurate than this Versa???
12-04-2018 15:12
12-04-2018 15:12
12-04-2018 15:27
12-04-2018 15:27
Best Answer12-04-2018 15:59
12-04-2018 15:59
Best Answer12-18-2018 08:57
12-18-2018 08:57
Did anyone get a fix for this? I just ended a live chat with support and they just told me I'm stuck with a faulty Versa, no fix, no replacement.
Feeling pretty stupid with my purchase right now!
Best Answer12-18-2018 09:02
12-18-2018 09:02
Best Answer12-18-2018 09:59 - last edited on 10-24-2019 19:26 by LiliyaFitbit
If Fitbit support told you that there is no fix, that probably means it is
a hardware issue.
Software can generally be fixed but hardware cannot.
If you have had your Versa for a short time you might be able to return it.
Try Googling "fitbit lawsuits"
Good luck
Jim
Best Answer12-19-2018 03:47
12-19-2018 03:47
Best Answer12-19-2018 05:31 - last edited on 10-24-2019 19:26 by LiliyaFitbit
I would suggest you consider Apple and Garmin products.
Best Answer12-20-2018 11:45
12-20-2018 11:45
Having the exact same issue switching from Charge 2 to Versa and wondering what’s happening now that it’s almost 2019... my runs used to spend most of their time in orange / cardio and now they’re in red / peak.... just after switching devices.
12-20-2018 13:24 - last edited on 10-24-2019 19:26 by LiliyaFitbit
I think we are doomed to live with this Versa (hardware?) problem. It is
not going to get fixed.
Best Answer12-20-2018 14:33
12-20-2018 14:33
Yes, and all of the "support" provided so far is complete and utter mediocrity. I was told that I cannot get a replacement because they can't ensure that the new monitor won't have the same problem... Yet... Fitbit continues to sell Versa all over the world...
This is textbook "greedy corporation" behavior.
I told the support rep that I am "willing to take my chances" with a new device, but they said NO. I told them that I have valid warranty, that Fitbit states that I get a replacement if my monitor has defects. But NO again... I am very upset and completely ready to be done with this deplorable company.
Screw Fitbit.
