04-21-2018
09:22
11:42
RobertoME
04-21-2018
09:22
11:42
RobertoME
I just went on my first run with the Versa and found the heart rate wildly off. I've had several other Fitbit devices that have registered a peak rate between 160-165 bpm for the same run, on the same wrist, with the same wrist placement. This run shows a lengthy section where my heart rate peaks at 209. I'm in my late 40's... No way that is accurate. Anything I can do to fix this?
Moderator Edit: Updated Subject For Clarity.
04-27-2018 04:29
04-27-2018 04:29
Best Answer04-27-2018 06:10
04-27-2018 06:10
Same here. With Charge HR2 average HR was within 2 or 3 of my Garmin heart strap. Now with Versa I am 20 higher and peaking at over 200 at 50 years old. It's also driving down my cardio fitness score each time I run. Have tried repositioning and tightening but makes no difference
04-27-2018 09:50
04-27-2018 09:50
I just removed my device on my phone then swiped the screen on the Versa to SETTINGS then went to reset to factory. Make sure to unpair your device under the bluetooth settings on your phone too. Then readd the device. It is actually pushing an update to my phone now so they must have pushed out firemware but it wasn't downloading. Hopefully this addresses this issue.
Best Answer04-27-2018 10:33
04-27-2018 10:33
Had this from Fitbit support, ignore the Ionic reference! Will try a run at the weekend and see if it fixes things, not too hopeful as I had already done several resets and they made no difference:
We are part of the Versa team and we'll be happy to assist you. We can assure we are working on this to get this solved as soon as possible. We appreciate the information you provided us.
In order to further investigate about this issue, could you please be so kind to follow the next steps:
- Go to Settings on your watch
- Tap Heart rate (OF)
- Sync your Ionic
- Tap Heart Rate (ON)
- Sync your tracker.
Best Answer04-28-2018 07:55 - edited 04-28-2018 08:20
I'll be returning mine today. The Versa has been out for 15 days (April 12 release) and they haven't fixed this. I've had mine for 9 days, in my opinion a perfectly reasonable amount of time to wait for an update. I'll be moving to Garmin Vivoactive 3. As I sit at my desk typing this on my laptop my Versa says my heart rate is 100.
09:01
14:58
LizzyFitbit
04-28-2018
09:01
14:58
LizzyFitbit
Recovery Runner, I have no vested interest in Fitbit but here’s what I did.
Returned and got another from REI. They have a one tear return on dffective
electronics and I was told that inaccurate measures would qualify. If I
don’t like the aesthetics it’s 90 days. Their return policy gives me some
peace of mind that I won’t be stuck with a lemon. If Fitbit can’t fix it in
a year that would certainly convince me that it’s a lemon.
Moderator Edit: Formatting
Best Answer04-28-2018 09:10
04-28-2018 09:10
Hi Jim. What is REI?
09:26
14:59
LizzyFitbit
04-28-2018
09:26
14:59
LizzyFitbit
REI is a large outdoor recreational equipment store. Members get a 10%
end-of-year debate.
https://www.rei.com/
Best Answer04-28-2018 09:34
04-28-2018 09:34
Thanks Jim. I was curious. I live in Canada so I’m hooped for buying one there
Best Answer04-28-2018 12:01
04-28-2018 12:01
Best Answer04-28-2018 12:04
04-28-2018 12:04
@tiim The unit I have right now is my second from REI. I returned the first thinking it was that unit but this one is exactly the same.
Best Answer04-28-2018 12:39
04-28-2018 12:39
After both reset attempts, I just completed my half marathon and it was over a mile off for distance and said I was peak at 197 for 2 hours. Will be contacting customer service again and most likely returning. So disappointing I don’t have accurate info for my big race.
Best Answer04-28-2018 13:40
04-28-2018 13:40
Best Answer04-28-2018 15:00
04-28-2018 15:00
@arf78 I tried the same advice I received from support (turn HR off, sync, turn HR on, sync). It did not work for my run this an. I tried to make sure the placement was correct on my wrist. My HR peaked at 194 twice during my casual 3 mile run. My HR average is higher than runs with my Blaze. Has anyone heard any definitive information from Fitbit Support that they recognize the problem & they're fixing it? They mentioned it early last week once during one of my email exchange but I haven't heard any updates.
Best Answer04-28-2018 15:01
04-28-2018 15:01
@arf78 I tried the same advice I received from support (turn HR off, sync, turn HR on, sync). It did not work for my run this am. I tried to make sure the placement was correct on my wrist. My HR peaked at 194 twice during my casual 3 mile run. My HR average is higher than runs with my Blaze. Has anyone heard any definitive information from Fitbit Support that they recognize the problem & they're fixing it? They mentioned it early last week once during one of my email exchange but I haven't heard any updates.
15:04
14:59
LizzyFitbit
04-28-2018
15:04
14:59
LizzyFitbit
A few days ago I was told “we have a team working on it” but no dates.
Best Answer04-28-2018 16:12
04-28-2018 16:12
I’m having a similar issue. My resting HR IS 58-63ish. My Versa is telling me 80-90! I’m very disappointed as I really was hoping this would be accurate. I think I’m going to end up having to return it:(
Best Answer04-28-2018 21:07
04-28-2018 21:07
Did you at least PR??
Best Answer04-29-2018 05:24
04-29-2018 05:24
Ha THANK YOU for asking. I did! Somehow! I don’t know how. It was my third half and triple my training elevation gain but I finished in 1:59:49!
Best Answer04-29-2018 05:47
04-29-2018 05:47
Followed HR reset and run stats are much more reasonable for same run. Before reset avg 179, max 203 after reset avg 158, max 175. Be interested if others have seen similar changes. Also not sure why such a popular thread has had no moderator comments if the fix is as simple as switching HR on and off. Back to being very happy with my Versa and the smaller bugs I am getting I am sure will be fixed soon too.....
