05-13-2019 03:27
05-13-2019 03:27
My versa has gotten stuck on a high number and seems to think my heart rate is constantly in the cardio zone - even when I am sleeping. I have tried all the suggestions in the community such as resetting, restarting and syncing etc. I have even had a live chat with fitbit who tried to fix it but are now telling me there is a big with the software; has anyone else heard of this bug? I feel like I'm being fobbed off.
Thanks
Gill
05-13-2019 13:14
05-13-2019 13:14
Hi Gill, you wrote: "I feel like I'm being fobbed off". IMO, your gut feeling is totally correct. Not monitoring the HR is a bug, yes, but this isn't. Mine does usually not have that, sometimes it does, but then I take it off my wrist for 15 minutes and it acts normally again. Try the following:
1. go to the setting of your Versa and to HR and disable it.
2. Restart your Versa 4-6 times in a row by pressing and holding the left and right lower buttons together untill you see after each restart the Fitbit logo and release the buttons. This resets the internal system of your Versa.
3. Go back to settings and HR and enable it again and see if the problem is solved.
BTW, just for certainty: are you using a Third Party Clock Face? If yes, change it to one developed by Fitbit itself and restart your Versa. in this case you can forget the above mentioned steps. Good luck!!
Best Answer05-13-2019 13:35
05-13-2019 13:35
Best Answer05-13-2019 13:40
05-13-2019 13:40
Hi Gill, I brought your problem under the attention of the Moderator Team. One of them will contact you soon via this topic.
05-13-2019 13:53
05-13-2019 13:53
Best Answer05-13-2019 13:58 - edited 05-13-2019 13:59
Many thanks for your very nice compliment, but no, I do not work for Fitbit. I'm just a user like you are. If I worked for Fitbit, I already had contacted the support team with your problem. Whenever a Moderator contacts the support tean, usually things are speeded up, so I really hope someone jumps in very soon.
Best Answer05-13-2019 14:01
05-13-2019 14:01
05-13-2019 14:03 - edited 05-13-2019 14:28
Hi Gill, that's why I'm around to try to help users, like you, with problems the best possible way I can!!
See also this (has nothing to do with your problem, but explains why I know so much about Smarwatches, cause they are not really different from Smartphones): https://forum.xda-developers.com/smartwatch/fitbit-watches/fitbit-versa-t3875174?nocache=1.
05-13-2019 14:32
05-13-2019 14:32
Hi Gill, see my last edited post!!
Best Answer05-13-2019 19:51
05-13-2019 19:51
@GH2000 Welcome to the Fitbit Community.
I'm sorry to hear that your heart rate readings are too high. Thank you for the time you spent trying to get it corrected. As you mentioned, our team is aware of this problem, but may not be able to provide a fix in the immediate future. We'll continue to monitor the situation, and keep our team informed of the impact to you and other users.
We understand that this isn't the resolution you're hoping for, but rest assured we're always working to improve our products.
I'm sorry for any trouble this could cause to you. Your patience is highly appreciated, we'll look forward to getting you back on track.
@SunsetRunner Thanks for your support.
Please let us know if you have any other question
05-14-2019 06:35
05-14-2019 06:35
I'm having the same problem! They told me it is a bug in the new software update. Yesterday, its saying I was active 460 minutes and burnt 4412 calories.🤦:female_sign: trust me, that did not happen. I was quite lazy yesterday. They had me restart it, uninstall and reinstall it, and then told me it was a bug. They said there Is no point in replacing it because it is the versa and iconic update.
Best Answer05-14-2019 06:50
05-14-2019 06:50
I am also having the same problem - my resting heart rate all day has been around 180, which is clearly not right. I have tried ALL proposed solutions (all the resets, restarts, etc.) and nothing has corrected the issue. If this is truly a bug in the software update, does anyone know when it will be fixed?
Best Answer05-14-2019 08:15
05-14-2019 08:15
Best Answer05-14-2019 08:16
05-14-2019 08:16
Best Answer05-14-2019 08:22
05-14-2019 08:22
It was random, just this morning while I was getting ready for work. I was on a chat with a representative for a quite a while, and she just kept telling me they are working on a solution but have no time frame. So frustrating!
Best Answer05-14-2019 09:32
05-14-2019 09:32
Best Answer05-14-2019 09:57
05-14-2019 09:57
I went to Best buy to geek squad and they fixed mine.
05-14-2019 10:18
05-14-2019 10:18
Do you have to have purchased it at Best Buy for them to fix it? How much did it cost? Thanks!
Best Answer05-14-2019 10:24
05-14-2019 10:24
Best Answer05-14-2019 11:50
05-14-2019 11:50
