08-27-2020
19:53
14:47
LizzyFitbit
08-27-2020
19:53
14:47
LizzyFitbit
After the most recent update my zone minutes are not added up correctly. Although the graph and Average heart rate show that I reached cardio and fat burn levels of heart activity (shown in orange and yellow), all minutes are shows as below zones. I have an iPhone 11 and a versa 2. All devices are updated. I’m not concerned with with small gaps in data but the minutes do not add up correctly in reference to the graph. This happens even when there is no gap in data.
10-06-2020
18:21
13:37
LizzyFitbit
10-06-2020
18:21
13:37
LizzyFitbit
Marv...tried to set custom heart rate zones on web version (due to iOS APP bug) as you suggested but it repeatedly said, ‘unable to update at this time, try again’. Was on phone with support over 2 hrs & they opened a ticket. They indicated that even when you set custom min & max zones, it’s not a real time update & won’t take effect until midnight (FYI).
Also...support looked at my fat burn, cardio, & peak heart rate zone history #s (prior to firmware update when everything went to hel- in a hand basket) & gave me the min & max #’s to set in ‘custom’. Supposedly after I’m able to set the custom HR min/max #s, my exercise zone data will reflect #s similar to what I used to get prior to the update. Praying this works 🙏 Thx for your help!
Moderator Edit: Formatting
10-06-2020 19:13
10-06-2020 19:13
@NancyB -
Before posting the response below (after the "++++") I decided to try an change my Max HR to a different value (110 instead of 120).
I clicked on submit and nothing happened - no "submission accepted" message or anything of that nature. I clicked on another link and then came back to Personal Settings and the original value 120 was there.
We'll see what happens tomorrow. Maybe something did change in the past 48 hours.
Unless something has changed in the past couple days, what support said about not taking effect until midnight is a bunch of hooey. I actually started a thread about them changing the Max HR back to the Traditional value at approximately 11:30 PDT on October 3rd.
I have actually made the change effective during a treadmill workout initiated on my Versa 2. I kept walking, pause the Netflix movie on my iPad, made the Max HR change in the web setting page on my iPad, sync'd my device using my iPhone and the change was effecting immediately after syncing. My heart rate zone representation changed - like I said - in the middle of the workout - on both the iOS app and the Versa 2.
So, support is either misinformed, which with my dealings with them in the past, is not surprising, or they lied to you, which is also not surprising - unless, of course the rules changed in the past 48 hours or so - - - Riiiiiiight.
Good luck.
10-07-2020 08:34
10-07-2020 08:34
Thx for your insight. I checked my settings on the web version & APP this a.m. & though it showed the custom zone #’s I set yest, my fat burn, cardio & peak data does not reflect that change. So, I attempted to set the custom zone #’s again & got this error msg (same one I kept getting yest.) 😡
10-07-2020 11:39
10-07-2020 11:39
@NancyB -
No change in the Max HR overnight. Still cannot change it in the Settings page - I tried changing to 115 from 120 - locked into 120. Which for me, is what I need.
It's nice when a "bug" goes your way.
Sorry it's not going yours.
I suspect the server will reset mine back to 152 and not allow me to change it.
Good luck.
10-10-2020 19:37
10-10-2020 19:37
I had the same issue. My zone minutes were there before the firmware update and then gone after the update 😣
11-02-2020 08:25
11-02-2020 08:25
I have the same issue after updating, has anyone been able to solve it?
11-26-2020 12:53
11-26-2020 12:53
I just got the sense Watch and today the same thing happened to me!!! Why is this happening and when will this glitch get fixed??? Up to now... not impressed 😒
12-07-2020 15:36
12-07-2020 15:36
I wish I had known this was an issue before I updated. I just got the firmware update notification and updated only to find it broke my new versa 2 (which was already a warranty replacement for my previous versa 2, which was also glitched itself into a non-functioning state). Apparently a functioning product is too much to ask from fitbit, I'm really unimpressed. Maybe don't continue to push firmware updates that are known to cause issues??? Or give me a way to uninstall the update so I can actually have a functioning product???
12-08-2020 09:53
12-08-2020 09:53
12-09-2020
13:58
07:07
JuanJoFitbit
12-09-2020
13:58
07:07
JuanJoFitbit
I want the old active minute feature, not the zone calculation..chatted with fitbit and they recommend keep complaining..said as of now, no way to delete the update to revert back. i think it is bs that they did this without notifying of this change. Programs are developed measuring active minutes, not zone.
Yeah, the switched the calculation with the update..said we have to keep complaining to have the option to revert it back to active minutes vs the zone
Moderator edit: merged reply
12-09-2020 17:42
12-09-2020 17:42
It's been so long since I commented about this. I thought I was good with the zone minutes, but I really continue to try to figure out what my actual minutes are. It seems so ridiculous to have Zone minutes and I am pretty sure mine calculate very inconsistently. In otherwords, I can do a 30 minute ride at a relatively low power output which I know isn't as much cardio as a 45 minute high intensity ride...but yet, the 30 minute ride yields greater Zone minutes. That doesn't make sense!!! Is this where we complain or do we file a formal complaint some place else?
01-07-2021 21:29
01-07-2021 21:29
Same issue with Versa 2 after update.
02-16-2021 12:12
02-16-2021 12:12
Did anyone figure out a fix for this?! I've had the exact same thing happen for 2 of my last 3 runs and it's so frustrating. Fitbit support have been no use to me in trying to figure out why.
02-16-2021 12:25
02-16-2021 12:25
02-17-2021 09:31
02-17-2021 09:31
That's a shame 😞 does it do it for yours still? Does it do it every time or just on occasion?
02-17-2021 12:37
02-17-2021 12:37
02-21-2021
09:20
04:56
02-21-2021
09:20
04:56
Hey @MikeGoll, it's great to see you around.
I appreciate the information provided, I know that our friends having this heart rate issue will find your post really helpful. If there is anything we can help you with, do not hesitate to post it.
Happy stepping!
03-06-2021 08:39
03-06-2021 08:39
Sad to say but Fitbit doesn’t care what we think & now that Google owns Fitbit I’m sure they care even less (their goal is our personal data). When they switched to zone mins with the firmware update last Sept, lots of us complained in this forum & called support. It’s 6 mos later & still no change. Battery life is also worse & charges take forever to go from 99% to 100%. I opened 2 tickets last Sept. & never heard back from anyone. I find my Versa to be pretty useless now & only use it to track steps, distance & weight (like I did w/gen 1 Flex back in 2014).
04-09-2021 11:11
04-09-2021 11:11
Hi there,
It is now 8 months later, and I am currently experiencing the very same issue with my zone minutes. Fitbit still hasn't figured out this issue.
Thanks,
04-23-2021 07:13
04-23-2021 07:13
That looks like it happened to you months ago it’s happening to me right now I’ve barely had this thing for a month for the first month it was exactly like my old Fitbit gave me the numbers said that I was in cardio and fat zones at all the appropriate times and now it just says I’m under zone all the time even when I’m struggling to breathe during a work out it says I didn’t go up and then he zones.
