09-26-2020
07:35
09:13
JuanJoFitbit
09-26-2020
07:35
09:13
JuanJoFitbit
How accurate is the HRV in the health metrics?
10-17-2020 11:03
10-17-2020 11:03
interesting! I'd be curious to see what it shows for your morning reading! Thanks for sharing!
10-17-2020 14:30
10-17-2020 14:30
@Jacko99 rMSDD in the morning usually is a lot higher. For me, rMSDD never went below 70ms in the morning readiness measuring. The thing is, Fitbit uses inaccurate sensor to measure HRV despite the sensor hasn't been designed for that purpose. HRV requires great accuracy. I am curious whether Sense could actually use ECG feature to measure HRV, then I could consider greater level of accuracy. Otherwise, HRV is just a buzzword to sell more devices but with no practical use for users.
10-18-2020 03:52
10-18-2020 03:52
Took a morning reading with Polar / EliteHRV: 50MS (26.52 RMSSD) - bit sore from weight training and running a couple of 5ks this week, so taking a couple of days off... Fitbit Sense shows 19. Clearly something amiss with Fitbit. Agree t.parker, hopefully Fitbit could utilise ECG to support the HRV reading but until then I will use Polar / EliteHRV.
10-23-2020 09:45
10-23-2020 09:45
Phew...another one who's super-relieved to find this thread!
I was so happy when I saw the HRV Data feature on my FitBit app, but for the past few weeks have started thinking I should speak to my doctor about a shockingly low HRV (18-21).
My RHR is consistently around 70 and I'm generally fit and active. I honestly thought the low HRV was a warning of some undiscovered heart defect!
Phew, phew, and phew once more!
10-30-2020 08:46
10-30-2020 08:46
I've been using an app called Welltory on my phone to track my HRV. It uses the camera on my phone to take measurements and certainly isn't as accurate as EliteHRV and a chest strap.
However, its measurements are similar to my overnight FitBit HRV, making me think that the FitBit HRV is probably reasonably accurate given the technology limitations.
Various things, including stress and health conditions, can lower HRV. For some people, theirs is just naturally lower as well. Mine varies quite a lot during the day, according to Welltory, but tends to run low.
02-26-2021 09:41
02-26-2021 09:41
If there are so many of us with this issue, when will FitBit fix it? It seems irresponsible to be scaring the pants off of people unnecessarily.
At 18 hrv, I was worried!!
03-29-2021 06:37
03-29-2021 06:37
It's not accurate at all. It's really to be used as a base line/ bench mark for trending. So the actual number isn't important, it's the trend of how the number changes over time that matters. If you see your hrv increasing, that's positive and indicates overall improving health. If it goes down, the opposite. Fluctuations of 1-3 milliseconds is normal. If you want an accurate hrv number, a chest strap hrm and any hrv app will do the trick. My Fitbit shows my hrv at around 35 on average. Pretty consistent plus or minus a couple of milliseconds over the course of the past month. Chest strap has my hrv at 69, which is more accurate based on my age and fitness level. So again, the Fitbit number is NOT accurate, but the trending seems to be ok. So don't stress about it. Hope this helps.
04-01-2021 20:06 - edited 04-01-2021 20:06
Google brought me here with a 31 HRV panic. 60 RHR and 99% on a separate pulse Ox tool. Work out 5 days a week. A little heavy but, not huge.
I’m curious when this will actually be worth looking at now.
05-20-2021 11:37
05-20-2021 11:37
I am so grateful to find this thread. I was really getting worried for nothing! I was also thinking I should go see a heart dr. Geesh. Thanks everyone!
05-29-2021 17:08
05-29-2021 17:08
There’s another thread on this topic ... general consensus is that Fitbit’s HRV is not accurate.
The issue has been highlighted to Fitbit ... but they won’t act on it unless there are sufficient users voicing the issue. Have your say here ... hopefully, Fitbit will take notice rather than just use HRV as a marketing gimmick and cause concern to users:
https://community.fitbit.com/t5/Feature-Suggestions/Improve-HRV-measurements-accuracy/idi-p/4853102
06-15-2021 13:51
06-15-2021 13:51
God I'm glad I found this thread. I'm 27 and my resting heart rate is 61, I exercise regularly and eat healthy, and yet my hrv has been showing up as 43.
07-20-2021 13:13
07-20-2021 13:13
Hi! Just wondering if any new news...my HRV on Inspire is always around 11 😞 I am always freaked out. I am about 40 pounds over weight..but am working on it with excercise and diet...But I don't know what to do or how it see if there is really a problem or not..just wondering if anyone knows..a lot of you are like 20 etc...11 sometimes goes to 9 ...highest like 2 times it was 20....any advice?
07-24-2021 15:55
07-24-2021 15:55
Did you ever find out if it’s accurate? I just checked mine for the first time and it’s as low as yours. I’m so freaked out!
07-24-2021 16:17
07-24-2021 16:17
Don't be freaked out. It is NOT accurate. Had mine checked at my cardiologist and Fitbit isn't even close to being accurate. Use it as a baseline or not at all. If you are still concerned or have other symptoms please see your doctor.
07-25-2021 08:55
07-25-2021 08:55
Thanks! I hope it’s wildly inaccurate because mine was 10 this morning! I’m not overweight but haven’t been exercising too much in the last year. I think I should put in a call to my cardiologist just in case!
07-25-2021 11:45
07-25-2021 11:45
09-21-2021
03:28
09:11
JuanJoFitbit
09-21-2021
03:28
09:11
JuanJoFitbit
Hi Sarah
this is my first time in the forum, my hrv is 7 or 8, so I’m a bit worried too being an overweight 71 year man who was given an inspire on my 70th birthday it I do a bit of exercise but not much
Not sure what I should do now breathing rate is 12 per min and resting heart rate 75
seeing a doctor in England is like winning the lottery
Thought I’d join the club my hrv 7 or 8
Moderator edit: merged reply
09-21-2021 15:07
09-21-2021 15:07
10-13-2021 02:15
10-13-2021 02:15
11-05-2021 05:01
11-05-2021 05:01
I am at 17 today...yesterday 20....going downhill quickly...
