01-29-2019
11:44
15:53
DavideFitbit
01-29-2019
11:44
15:53
DavideFitbit
Weather unit How can I change the whether Unit To Fahrenheit
01-29-2019 12:15
01-29-2019 12:15
Hi, go to Apps within Fitbit app and press it. You'll see My apps and All Apps. In My apps all apps are listed that are installed on your Versa. Scroll down the list untill you see the Weather app. Press the settings icon right next to it and you get a page that starts with Temperature Unit. Press on unit directly beneath that and you can choose between Celsius or Fahrenheit. click the one you want and press "Done" on the right side on the bottom. Ready!!
