08-05-2022
07:18
17:34
08-05-2022
07:18
17:34
Hi, is it possible to add hiking to my auto recognised activities on my versa 3. I had it on previous fitbits. Thanks
08-05-2022 08:30
08-05-2022 08:30
@DevonJane Please take some time to familiarize yourself with the Exercise app on the Versa 3. Once you use Hike, it will be at the top of your list.
Laurie | Maryland
Best Answer08-05-2022 07:32
08-05-2022 07:32
Hello @DevonJane
Open your Fitbit app, tap your profile picture then scroll down to Versa 3 then scroll down and tap exercise shortcuts. If hiking is not currently showing delete one that is pre-loaded, then select ""Hike" from the list of possibilities.
😃 Remember to sync your Versa 3 for the change to take effect. I hope this provided you with the best answer and gets you up and running with Hiking as an option now. Please let me know
Best Answer08-05-2022 07:58
08-05-2022 07:58
Thanks sorry I shoukdve said in not able to delete one, previously when using charge 5 I could swipe left and remove one now the app wont let me swipe.
08-05-2022 07:59
08-05-2022 07:59
Sorry @DevonJane but hiking is not one of the auto detectable exercises.
Walking is, but when hiking, the arm movements and timing may not be predictable enough.
Do all people hike with poles or some without? This would have a big effect on the arm movement.
Hiking is already in the manual exercise functions.
08-05-2022 08:10
08-05-2022 08:10
@DevonJane You mention swiping and changing exercise shortcuts. That is used with the exercise shortcuts on your phone. The Versa 3 exercise shortcuts are all on the device itself. Swipe to go to your Exercise app on your Versa 3. All of the Exercise shortcuts are in alphabetical order. After you use one, the list changes to Recent and everything else in alphabetical order. @Rich_Laue is correct. Hiking has never been on the list of auto recognized exercises.
Laurie | Maryland
Best Answer08-05-2022 08:12
08-05-2022 08:12
08-05-2022 08:19
08-05-2022 08:19
08-05-2022 08:20
08-05-2022 08:20
08-05-2022 08:30
08-05-2022 08:30
Laurie | Maryland
Best Answer08-05-2022 11:12
08-05-2022 11:12
