07-05-2018 16:35
07-05-2018 16:35
I just received my new Versa and I want to add it as a device (primary) and still keep my Ionic connected as secondary. I plan on using the Versa most of the time but will use my Ionic for runs and its GPS. I don't have a smartphone for the GPS so I need and want my Ionic connected to as a secondary device.
07-05-2018 17:39
07-05-2018 17:39
Hi @kb7vbz This is likely not the answer you are looking for, but currently you can't have both an Ionic and a Versa connected. However, it's easy and quick to swap them out and you don't lose any of your device settings, like clock face. I have both devices and use my Versa as primary now, so I'm speaking from personal experience, that it takes less than 3 minutes to add the Ionic back to your account, the system removes the Versa and you are good to go. Just make sure you sync before switching trackers. I hope that helps.
07-06-2018 01:26
07-06-2018 01:26
As @MarciM said, swapping them takes a few minutes and most of the settings are preserved. I did notice though when I swapped between mine, I had to re-enter my WiFi network settings (Password), and also my exercise shortcuts reverted back to the default ones.
You might be interested voting on the feature suggestion allow both Ionic and Versa on the same account. Hopefully the more votes this gets, the greater chance it has of being implemented.
