05-01-2023 14:10
05-01-2023 14:10
I’ve tried to get the original clock face on my watch but don’t know how. It’s not in my clock faces. Can’t seem to find it. Can I even change it back without lising all my data?
05-01-2023
21:05
17:06
05-01-2023
21:05
17:06
Hi @vandy1 - changing clock face doesn't lose data.
But you are limited to 5 clock faces and if you have 5 you will need to remove one (not the active one) before installing any other.
In the Fitbit App, click profile photo and device photo and Gallery tile.
You will see which and how many clock faces you have, one might be the original already so just select it, or when you see an empty slot click it and search for Waveform and install it.
Note, it is a good idea to make a note of any clock face names so you can reinstall them again later if you decide you want one back.
