09-19-2023
22:22
06:08
09-19-2023
22:22
06:08
There is no clock face option on my Fitbit app. I’ve tried all the resets and closed the app etc, there is just no option at all. Any suggestions..
09-20-2023 02:57
09-20-2023 02:57
Welcome to the Fitbit community, @hollie_blu!
To change the clock face on your device please tap Gallery, then the Clocks tab. To get to the Clocks gallery, you must have no more than 38 apps installed on your device. More on that here:
How do I change the clock face on my Fitbit device?
09-20-2023 05:13
09-20-2023 05:13
Hi @hollie_blu - for information, you may find some old posts, but the page you posted here was changed a while back and clocks and apps were consolidated under Gallery.
You can save a maximum of 5 clocks on your watch and switch between them using the watch Clocks app.
As regards loading apps, there is a limit to the number the watch supports, it used to be around 30, depending on the presence of certain system apps. Unfortunately there is no warning if the limit has been reached.
