How do I change the clock face on my Versa 2?
New purchase January 2025.There is no option as described to get to clock face option. I am signed in through Google. Any help would be appreciated!
Moderator Edit: Clarified subject and label.
4 REPLIES 4
Hey there @ChaCha2025, welcome to the Fitbit Community.
Let me help you resolve this issue with your Versa 2 clock faces!
To start, could you tell me more about what's happening? Are you unable to change the clock face on your Versa 2? Or is there an issue with the display itself?
There is no option to get to clock face as described on fitbit versa 2
There is option for gallery or apps
Hi @ChaCha2025 - on your watch when you swipe the face to the left do you see a Clock's app? If so you can use it to change clock face if there is already more than 1.
In the Fitbit App, Gallery tile, (Versa 2 tab at the top) you can also see or select clock faces, or use the clocks tab to add new clock faces.
Thanks @Guy_ for your advice and knowledge you have shared with us! @ChaCha2025 Let us know if the suggestions above were helpful for you. You can also take a look at this article if needed.
