01-10-2021 21:23
01-10-2021 21:23
How do I change the lap length on my fitbit versa? I swim in 50m pools, but it defaults to 25m for lengths. Instructions I have found don't work as there are no settings (advanced or otherwise) to change this.
Everything else works and syncs ok.
01-10-2021 23:26
01-10-2021 23:26
Hi,
When you select Swim as an exercise there is a small gear in the top right corner, you can change it there.
It remembers it so don't for get to change it if you use other pools.
01-10-2021 23:26
01-10-2021 23:26
Hi,
01-10-2021 23:41
01-10-2021 23:41
Legend! Thank you!
