02-04-2024
08:59
06:42
02-04-2024
08:59
06:42
02-04-2024 19:25
02-05-2024 06:49
02-05-2024 06:49
Hi there, @DwainB. Welcome to the Fitbit Community Forums.
As @Guy_ has recommended, you can change the weather units as follows:
If the above doesn't do the trick, I'd recommend to try switching to a clock face that actually shows both units of measurements, Celsius and Fahrenheit, as not all clock faces will show the temperature in Celsius or Fahrenheit even when you've set it to be that way, probably that would explain why none of the clock faces you've tried have worked so far. For more information, see How do I change the clock face on my Fitbit device?
