04-20-2018
03:32
08:00
AlejandraFitbit
04-20-2018
03:32
08:00
AlejandraFitbit
How do I take my Versa off of military time?
04-20-2018 03:48
04-20-2018 03:48
You can choose between 12 and 24 hour clocks in your profile settings at https://www.fitbit.com/user/profile/edit
Once changed and saved, the next time you sync your fitbit will be updated
04-20-2018 03:48
04-20-2018 03:48
07-14-2018 19:41
07-14-2018 19:41
Wow didn't realize it would be that easy thanks!
07-16-2018 08:01
07-16-2018 08:01
01-22-2019 10:25
01-22-2019 10:25
I made those changes but my calendar still shows military time.
01-22-2019 10:41
01-22-2019 10:41
01-22-2019 10:54
01-22-2019 10:54
It is set up for the right time Eastern on my computer and it still shows military on my calendar.
01-22-2019 10:56
01-22-2019 10:56
Is the calendar an app you are using? If so, I wonder if it overrides the profile settings. Is the main clockface showing correctly?
01-22-2019 12:42
01-22-2019 12:42
Upcoming. Do you have a better suggestion? I use this for my appointments. Thanks
12-27-2019 12:35
12-27-2019 12:35
Thanks. This did work for my Fitbit (Charge3). Do you know how to do it on my Kids Ace2 setup under my Family group?
