12-26-2018
06:22
16:53
EdsonFitbit
12-26-2018
06:22
16:53
EdsonFitbit
How do i connect my versa to my chromebook computer? How do i put music on to it?
Moderator edit: added label
12-26-2018 07:17 - edited 12-26-2018 07:23
Hi, as the chromebook is a PC, there is no seperate Fitbitapp available for computers. But if you have a Fitbit account and are logged in, put the Versa in the charger and connect it to your PC and hope that the USB port recognizes the Versa (no special drivers needed for that. If yes, just open your usual webbrowser (if you do not have a webbrowser yet, go to the Playstore and download one of your choice), type www.fitbit.com and it will bring you to your personal dashboard. If you do not have a Fitbit account, create one and the rest is the same. How you do put music on it, I do not know. Do you have a mobile device, if yes, which one?
12-26-2018 07:22
12-26-2018 07:22
@Carterdarr04 Here's a link for the Fitbit Connect or Fitbit app for the PC that permits music transfer. https://www.fitbit.com/setup Just scroll down to the bottom of the page and select the correct platform for your operating system.
What I'm concerned about is that a Chromebook runs Google's Chrome OS which isn't listed as an available platform. Perhaps you can figure out which is the best choice for your Chromebook or perhaps someone can weigh in about whether the Chromebook OS is compatible.
Best Answer12-26-2018 07:25
12-26-2018 07:25
Hi, nowadays it's possible to choose the browser of your choice via the Playstore on the chromebook, e.g. Firefox, Opera, etc.
Best Answer07-23-2022 07:44
07-23-2022 07:44
That trick also works with the Luxe, to my great delight
