How do I disconnect Bluetooth headphones?
Hi all,
After updating my versa to the new firmware, I am having trouble DISconnecting my headphones from the Versa (Yes, DIS connecting. Connecting isn`t a problem!)
Headphones are multipoint (moto S11-flex)
Once my headphones are paired with the Versa, it keeps on establishing a connection whenever the headphones are turned on. Normally that might be good, but, I use the bluetooth headphones to connect to the treadmill when running in the gym. When not on the treadmill, I stream music from my Versa.
How do I set the versa to disconnect, but not unpair from the headphones, so I can establish a connection to the treadmill?
3 REPLIES 3
Hi @Digit01, it's nice to see you again in our Community Forums.
I appreciate your participation in the Forums and sharing your concern on how to disconnect your Fitbit Versa from the headphones in order to establish a connection to the treadmill. Thank you for providing the additional details. If you connect several Bluetooth devices to your watch you can change the device your watch is connected to by following these steps:
  1. On your watch, open the Settings app.
  2. Tap Bluetooth.
  3. Tap the audio device you want to use. Then wait a moment for the device to connect.
You can remove an audio device connected to your watch by doing the following:
  2. Tap Bluetooth.
  3. Scroll down and tap Remove.
  4. Tap the device you want to remove and then tap Yes to confirm.
For more information, please see this help article: How do I connect Bluetooth audio devices to my Fitbit watch?
Thankyou for your answer. lillyafitbit.
You have very specifically given me a step by step instruction on how to do what I already know. You have not answered the problem. Not sure how to more clear, but I will try again.
-  I do not want to connect multiple devices to my Versa, so the first part of your answer is obselete.
- I do not want to remove (unpair) a device from my Versa, so the second part of your answer is obselete.
To restate the issue:
 I want to be able to manually drop  and re-establish the bluetooth connection to my paired headphones from my Versa WITHOUT going through the process of unpairing and re-pairing every time.
As it stands at the moment, every time I turn the headphones on with my Versa nearby, the Versa automatically connects, to the exclusion of other devices, and cannot be disconnected without fully unpairing.
I am hoping you can tell me otherwise.
Hi @Digit01, thank you for your reply. I am sorry for the delayed response.
Thank you for providing the additional details. I understand your point and recommend trying the following:
1. Swipe down from the top of the screen.
2. Change the audio source to your phone.
Let me know how it goes.
