02-07-2024
07:12
07:31
02-07-2024
07:12
07:31
How do I get my Versa to vibrate when I receive notifications?
02-07-2024 07:40
02-07-2024 07:40
Hi there, @Cindy65. Welcome to the Fitbit Community Forums.
As a first approach, please make sure that you've set up your notifications as per the instructions provided in this help article How do I get notifications from my phone on my Fitbit device?
If the notifications have been properly set up but you're still missing the vibrations, may I know if you're missing any other alerts? Please note that your Fitbit device vibrates to alert you at various times, including if you set an alarm, when you hit your step goal, or if you haven’t met your hourly activity goal. If your device didn't alert you for any of those, please see Why didn't my Fitbit device alert me?
02-07-2024 13:54
02-07-2024 13:54
02-07-2024 20:18
02-07-2024 20:18
Hi @Cindy65 - the watch may be faulty because it normally has a strong vibration on any setting which can be adjusted in the watch Settings.
Make a test with a timer or alarm to check if the vibration is working (they produce the strongest vibrations). Because if you get notifications on the watch it should vibrate by default.
