03-16-2024
02:41
05:15
03-16-2024
02:41
05:15
I have tried to check to see if there is an update for my devise but all I get on the app is the Fitbit logo flashing on the screen I have left it for a couple of hours before but no notification on if there is or isn’t one
03-16-2024 03:07
03-16-2024 03:07
I've just seen there was an update 12th march which was the same time my issue started. I had similar problems with the Feb update for a week or so and hoping it will correct itself.
03-16-2024 06:44
03-16-2024 06:44
@pottyremlap Hi. You mean the watch face has the fitbit logo? Never seen the Fitbit logo flashing on the mobile app. If there's an update, you'll see a notification in the mobile app. The Versa 2 hasn't had an update in a year or so. Latest version is 35.72.1.23. And app updates are across the board. They have nothing to do with what watch model you have.
@Suwy50 You're referring to mobile app updates right? Maybe post in the Android or IOS section?
03-16-2024 07:04
03-16-2024 07:04
Best Answer03-16-2024 07:15
03-16-2024 07:15
@Suwy50 No problem. I don't see any way possible a phone update can make your watch stop swiping. Have you tried restarting? Also maybe try chat support? You should be able to connect with a Fitbit employee in about 2 minutes.
Best Answer03-16-2024 11:02
03-16-2024 11:02
This is all I get when on the app trying to see if there is an update on my IPhone.
Best Answer03-16-2024 11:17
03-16-2024 11:17
@pottyremlap What do you mean see if there's an update? Phone app or Versa 2 update? The app works fine otherwise? Have you checked your firmware version? If you're running 35.72.1.23, there is no update. If you're trying to update the phone app, you don't do it through the fitbit app. Chat support is pretty instant. You'd likely have it resolved by now.
Best Answer03-16-2024 17:35
03-16-2024 17:35
That is all I get too when trying to see if my Fitbit needs updating
Best Answer03-16-2024 22:33
03-16-2024 22:33
Hi all, to clarify, if you see a blank screen or Fitbit logo on your telephone, swipe off the active window (and in Android clear the storage cache and force stop the Fitbit App) then restart the phone, for good measure restart the watch and try again, the Fitbit App can be buggy.
If the watch is stuck showing the Fitbit logo, then blanking, this is a more serious problem and may not be fixable, have a look at posts about stuck on logo.
Best Answer03-17-2024 09:33
03-17-2024 09:33
Same here. My watch will reboot but as soon as it blanks out, I can’t get the screen to come back on. Only way to get the time is a hard reboot if the watch every time. Checked the app for firmware update and get the Fitbit logo for hours.
